Extended Lube Device for Slide
  • 1 Replies
  • 8474 Views
sailors35
  • 94
  • PurchDate: May, 2017
  • ExtColor: Desert Sand
« on: October 21, 2020, 11:52:08 am »
Awhile back I posted about trying to lube slideout. Frustration was trying to follow the You Tube Video and the supposed ease of using an extended red tube on the CRC lube.  The good news is I found longer tubes at Aircraft Spruce & Specialty Company. Bad news: tubes were $3.50, shipping $11.79.  The rest of the story: due to the gasket/seals, flexibility of the tubes and difficulty in actually being able to see the recommended spots to lube I am not sure of the actual success, other than the slide continues to work fine.  So it  is done, but difficult to evaluate. pyho
Mike & Lynn Ratliff
faiello
  • 98
  • PurchDate: 08/2019
  • IntColor: Graystone/Cherry
Re: Extended Lube Device for Slide
« Reply #1 on: October 24, 2020, 09:55:24 pm »
This is a good video to watch on slide maintenance.
https://m.youtube.com/watch?v=pQlDsBsWe0w&t=124s
Frank & Beth
