2020 Vehicles to tow 4 down
  • 8725 Views
ginnyp
  • 6
  • PurchDate: OCT 2020
  • ModelYear: 2021
  • ExtColor: Desert Sand
« on: October 07, 2020, 05:36:19 pm »
I'm looking for recommendations for a new 2020 vehicle to tow 4 down.  I've looked at a Buick Envision, Ford Edge and a Lincoln Nautilus which supposedly can be towed - anyone have any information on the pros or cons for any of these vehicles - or something different that you would recommend?
Ginny P
Re: 2020 Vehicles to tow 4 down
« Reply #1 on: October 08, 2020, 07:57:59 am »
No vehicle recommendations but a tip on tow plates. We bought a new standard shift Subaru Forester to tow four down when we bought our rig. What a surprise to find out the chassis was a new design and no tow plates existed to fit it. We had to wait until the tow plate people got hold of the same model and fabricated a plate. I can't remember which company asked us to drive out to the Midwest and give them our new car for days so they could figure it out. We were still working and declined. It was quite a few months before we could get a tow plate for the car.
  • 5719
« Reply #2 on: October 08, 2020, 08:25:15 am »
2 Frazzled makes a very good point when buying a brand new vehicle, most especially after a new vehicle design change, even if only an adjustment in styling.
It is less risky to shop for a tow vehicle that is one or two model years old because tow bar companies like Roadmaster and Blue Ox have their interactive websites to select their existing products for past vehicles.
Plan on doing some extra research.  Just because a tow bar is made for a particular vehicle, doesn't mean you can tow it.  Especially years ago, it has been limited to manual transmission versions.  Some automatic transmission vehicles can be towed, but every 500 miles you have to start the engine and go through the gears to circulate automatic transmission fluid for internal lubrication protection.
Our first tow vehicle was a 2000 Toyota MR2 Spyder with a manual transmission.  That was an extremely easy tow vehicle.
Our second (and current) tow vehicle is a 2006 Jeep Liberty with an automatic transmission, but with an additional 4x4 gear transfer case.  We put that into neutral so the drive shaft to the automatic trans doesn't spin while the vehicle is being towed.
As of late, it seems there are fewer towing choices, maybe because there are fewer manual transmission vehicles, but also because the automatics have gotten more high tech with features like push-button transmission shifting, push button gear transfer case shifting, CVT technology, and so on.  I don't have statistics, but various model Jeeps seem to be most popular for one reason or another.  And I think they've had push button gear transfer case shifting for some time.  So there are exceptions to everything.
Regarding your specific choices, the Buick, Ford, and Lincoln, I would go to the dealer and ask to review the owner's manual.  Read through the section on 4-wheel-down towing.  Don't take anybody's word, not from here and surely not from any dealer.  Read it for yourself.  If you tow a vehicle not approved by the manufacture, you will void your new vehicle warranty.
« Last Edit: October 08, 2020, 08:49:10 am by Ron Dittmer »
Tjron47
  • 6
  • PurchDate: March 2020
« Reply #3 on: October 08, 2020, 10:54:32 am »
Hiya
Just got back to Arizona from our Summer on the Oregon Coast.  Traveled approx 2500 miles towing. We tow a 2018 Buick Envision with our 2552 no slide and have not had a problem.  Just have to take it easy on long up and down grades. Sweet-spot seems to be around 61/62 mph on flat land. Use an RVI brake for the braking system, put in neutral, pull 2 fuses and go. Easy hookup and disconnect.
