Bathroom shelfDW
  • 7831 Views
garmp
  • 354
  • PurchDate: 3/20
  • ModelYear: 2020 2351D
  • IntColor: Greystone
Bathroom shelfDW
« on: August 02, 2020, 08:32:08 pm »
DW would like a shelf added in the bathroom of our 2351D. I can make the shelf, match the decor, etc but not sure how to mount it to the wall. How thick are the walls? Don't want to drive a couple of screws into the wall and have them pertrude through the outside skin. Really don
t want to use those 3M Command thingies. Your thoughts?
Re: Bathroom shelfDW
« Reply #1 on: August 02, 2020, 10:29:16 pm »
I added a few shelves in our 2350 bathroom.  I used deep-thread, deep-bite wood screws, but I pre-drilled the holes large enough so the screws would not crumble the tempered hard board.  The holes are drilled a tiny bit larger than the inside diameter of the threads on the screws.
As far as the shelving I installed........
We roll up and store our bath towels in this rack mounted above the toilet.  It works well.  The towels are pressure-fit and don't fall out.  The towels in the picture don't reflect actual usage.
I made a toothbrush, toothpaste, and hand soap shelf made from the cabinet base door that I no longer needed after my galley cabinet reconfiguration.
« Last Edit: August 02, 2020, 10:33:56 pm by Ron Dittmer »
garmp
  • 354
  • PurchDate: 3/20
« Reply #2 on: August 03, 2020, 08:46:54 am »
I understand the predrilling and all, but my question is how thick are the walls. How long of a screw is too long?
« Reply #3 on: August 03, 2020, 09:22:41 am »
This might be of some help if you are talking about an outside wall.  I used a hole saw to install a second electrical feed receptical.  This photo is from the hole saw “core”.  As you can see it is about 1 3/8”.  The left side is the outer skin of the PC.  This is from a 2016 model 2552 so yours may be different.  I can’t help for interior dividing walls.
« Reply #4 on: August 03, 2020, 09:57:43 am »
Interior versus exterior walls will vary.  Drill a very tiny hole and insert an extra long hardened (skinny) trim nail to determine the working depth.  Use that same hole for a mounting hole.
The thickness of the wallpapered tempered hard board is 1/8" thick.
« Last Edit: August 03, 2020, 10:02:03 am by Ron Dittmer »
« Reply #5 on: August 03, 2020, 12:17:52 pm »
Any screw longer than the thickness of the wall board (thin) is wasted. I'd suggest a molly type wall anchor made for that thickness of wall board if you want it to stay put.
« Last Edit: August 03, 2020, 12:19:47 pm by 2 Lucky »
