Got locked in!
  • 9430 Views
Tarnold
  • 247
  • PurchDate: Dec 2019
Got locked in!
« on: July 18, 2020, 11:47:08 am »
Hint:  next time you have a philips head Screw driver in your hand check the 3 screws that hold the side door lock mechanism in.  Mine had backed out enough that it made the handle not make contact when pulled causing door to not open.
Re: Got locked in!
« Reply #1 on: July 19, 2020, 10:03:23 am »
There is a cast metal piece that is famous for leaving people trapped also. Be happy we have the Van doors... when researching my latch replacement, I found stories of class A folk going out the windows... :beg
Engineerlt
Re: Got locked in!
« Reply #2 on: July 20, 2020, 08:37:17 pm »
Hello Volkemon
Did you replace your door lock with a different type? Mine broke and I got another from PC. I am not a fan of the lock as the  bolt on the lock is made from pot metal and it brakes where the handle interfaces with the bolt. I might make the bolt out of steel on the lock I removed so i have a spare, I figure its just a matter of time before the new one breaks. That's why I am wondering if you found a different replacement than the tri-mark.
Lance
Re: Got locked in!
« Reply #3 on: July 21, 2020, 09:36:30 am »
Hello Volkemon
Lance
https://forum.phoenixusarv.com/index.php?topic=3454.0    2o2
Re: Got locked in!
« Reply #4 on: July 21, 2020, 03:43:15 pm »
If you get the RV Designer version (T507) of the TriMark 60-1650,it has a steel latch bolt.   A bit more expensive (on Amazon $150 vs $94 for the TriMark) but also warranted for life.
http://www.rvdesigner.com/prodview.asp?ci=18&pi=418
« Last Edit: July 21, 2020, 03:52:17 pm by donc13 »
