Water pressure
  • 7283 Views
Tarnold
  • 247
  • PurchDate: Dec 2019
Water pressure
« on: June 12, 2020, 10:31:15 am »
Fixing to leave on our only second trip.  Water tank full. Trying to flush out pink stuff.  No water in hot water heater yet.  Great pressure in back(2552) shower,sink, out side faucet.  However very little, just a trickle coming out of kitchen sink.  Valves under pull out drawer are set as inline (on) on h/c pipes,  and crossover off(closed). Is this correct? Both “dump” valve pull ups reset and closed.  Any other valve I haven’t found yet?
Tarnold
  • 247
Re: Water pressure
« Reply #1 on: June 12, 2020, 11:18:50 am »
Ok, got it.  Sink strainer 100% clogged.  CLR next
Re: Water pressure
« Reply #2 on: June 12, 2020, 01:22:35 pm »
The pink stuff tastes horrid.  Make sure you flush all lines completely including the outside shower if you have one.
Pink stuff won't hurt you, but taste is something special... In a negative sense!
Good Luck!
