Slide out- Help me with a problem with loose bolts?
  • 17 Replies
  • 23717 Views
flei
  • 89
  • PurchDate: 03/2020
  • IntColor: ?
  • ExtColor: ?
Re: Slide out- Help me with a problem with loose bolts?
« Reply #15 on: May 14, 2020, 12:21:28 pm »
Follow-up on the T-block issue.  PC has re-opened and I spoke to Doug at the factory today about this issue. He was very helpful. He stated that the situation I have is normal; that the T-blocks are in fact designed to "float" so that they can make small adjustments to the slider.  He stated that if necessary, one can access the heads of the bolts by removing small areas of carpet and flooring to create access under the sofa. I feel like I can rest easy now, knowing my slide-out isn't going to go off track!
« Reply #16 on: May 18, 2020, 02:06:19 pm »
Thanks for the follow up!    :)(:
Good to know what is 'normal'.  As far as the bolt length differences... I bet it was a 'field expedient' during construction, and if it hasnt caused an issue by now, let that dog sleep.    (exactly)
flei
  • 89
  • IntColor: ?
  • ExtColor: ?
« Reply #17 on: May 18, 2020, 02:57:05 pm »
Yup. The slide out works fine and it appears that the bolts are supposed to stick up, so I'm not going to touch it!  I feel like I dodged a bullet on this one!
