Flow-Rite Qwik-Fill™ Onboard Battery Watering System
  • 12722 Views
lghjr
  • 306
« on: February 28, 2011, 02:48:42 pm »
Anybody have experience with these battery filling devices?   Either boat or RV??
http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_52557_225007002_225000000_225007000?cmCat=CROSSSELL_PRODUCT
The batteries on my rig are impossible to check without unhooking and removing the batteries from the tray. Might be better if I replaced some of the parallel cables with with longer ones, but still............
I have a local Basspro but no CampingWorld, so that's why that reference.
Some designs use a reservoir for water but with the jostling on the road that looks like disaster waiting to happen to me.
Thanks, L. G.
Bob Mahon
  • 547
  • PurchDate: 6/2011
  • IntColor: Tan/Gray/Cherry
  • ExtColor: Lower Slate Gray
Re: Flow-Rite Qwik-Fill™ Onboard Battery Watering System
« Reply #1 on: February 28, 2011, 09:19:01 pm »
My opinions only:
I wouldn't consider an 'Automatic' battery watering system. I've had them and all had problems after a while (you still have to check reservoir water level). And they don't do a thing to assist in the periodic specific gravity checking.
Better to get longer cables so the batteries extend further, which allows water level checks, filling and Hydrometer usage.
lghjr
  • 306
« Reply #2 on: March 04, 2011, 03:34:42 pm »
Had the parts ordered from CW until I tried to check out and it was backorderd.
Tried the dealer I bought my PC from and he had a inclusive kit with everything at roughly $40 bucks cheaper so I purchased it - 3 years old new stock. I just got it put on and I filled the batteries (new) and I think I am going to like it a lot, let you know in a month or so if it stands up to me and acid.
L. G.
P.S. Basspro had it in the catalog/online, not on the store shelf though, at substantially more than Camping World +shi.  They still wanted shi to bring it to the store, such a deal.
« Last Edit: March 04, 2011, 03:37:46 pm by lghjr »
lghjr
  • 306
« Reply #3 on: April 13, 2011, 07:22:52 pm »
L. G.
Well it's been a month + and just charged the batteries.  Then filled with water, in about 2 minutes or less. Took longer to get the fill bulb out of the toolkit than it did to fill (old age, didn't remember where I put it).  Considering how hard it used to be to do the same job in basically an afternoon, the $60 bucks for the fill kit is heaven.  No spills, no leaks, no acid all over, no corrosion, greatest thing for this type installation.
I believe I am going to like it alot.
