Slide crank
  • 10209 Views
Tarnold
  • 247
  • PurchDate: Dec 2019
Slide crank
« on: December 20, 2019, 04:33:23 pm »
There is an access port in the bottom left that I read can be used with a crank the slide back in when all else fails.  Looked all over but can’t find one.  Please describe what this looks like.
Re: Slide crank
« Reply #1 on: December 20, 2019, 05:32:07 pm »
It's a crank... About 3' long, silver.  It comes from the factory in the rear storage area along with a bottle jack with pump handle & shore power cord.
Tarnold
  • 247
Re: Slide crank
« Reply #2 on: December 20, 2019, 06:08:58 pm »
No crank, no bottle jack.  Is there some kind of hex head on the end of the crank.  Is it something like the old folding crank that came with a ford pickup.  I could weld something up if I had approx dementions.
hutch42
  • 246
  • ModelYear: New TRX
Re: Slide crank
« Reply #3 on: December 21, 2019, 01:12:17 am »
Just a WAG.  PC switched to a Lippert/Schwintek slide a year or so ago.  Dont believe they have a manual crank system.
If you Goggle them they have a bunch of videos on how to electronically adjust, and operate the slide if it malfunctions
Hutch
« Last Edit: December 21, 2019, 11:31:30 am by hutch42 »
Re: Slide crank
« Reply #4 on: December 21, 2019, 07:25:21 am »
It's nothing special.   Pull the plastic cover off the hole in the slide or open the slide and look at it from the bottom.  My memory is it's just a hex head.  I could look at my crank but it's in storage several miles away.
You can also call the factory talk to Carol, I sure they can sell you a new one.
Re: Slide crank
« Reply #5 on: December 22, 2019, 06:57:49 am »
If you don't have a spare tire on the back, you won't have a jack.
Re: Slide crank
« Reply #6 on: December 22, 2019, 10:55:43 pm »
Phoenix accidentally included a manual crank with our PC even though we don't have a slide out.  It is nothing special.  I think you would be better off carrying a modest socket set in your tool box which will meet other emergency needs.
« Last Edit: December 22, 2019, 10:57:27 pm by Ron Dittmer »
