What air compressor do you carry?
  • 25 Replies
  • 27177 Views
garmp
  • 354
  • PurchDate: 3/20
  • ModelYear: 2020 2351D
  • IntColor: Greystone
« on: October 23, 2019, 05:00:05 pm »
Looking into getting an air compressor to carry, but have to find the right one. Has to be small, light weight with no or a very small tank. Capable of blowing up to an 80lb tire and preferable 110. And not to break the bank on something I'll hopefully not use frequently.
I looked at the Viair, but not fond of connecting to the battery, I don't know why. And there are so many models to choose from for some one who doesn't know squat about them.
So, what do you carry and why that one?
thanks
Re: What air compressor do you carry?
« Reply #1 on: October 23, 2019, 06:07:10 pm »
The small electric emergency air pump I have in a tire repair kit does not work efficiently to my satisfaction, so I am interested in the comments you receive.
« Reply #2 on: October 23, 2019, 06:39:07 pm »
https://www.lowes.com/pd/BLACK-DECKER-12-Volt-And-120-Volt-120-Lithium-Ion-Air-Inflator-Power-Source-Battery-Car-Electric/1000330671
Programmable inflation pressure,  160 psi max.
3 way power : 110v ac, 12v dc, or lithium ion battery (not included).
I bought it because it uses the same rechargeable battery pack as my B&D leaf blower. I used it to set the tire pressures when I installed my TPMS. The battery did the job no problem.  I use it to set my ride-rite air springs before each trip. The gauge is accurate, and it is designed to shut off 1.5 psi higher then the set point .
catsaplenty
  • 152
  • PurchDate: 3/17
  • IntColor: Sand
« Reply #3 on: October 23, 2019, 09:26:03 pm »
I also carry the Black and Decker though not with a battery pack  I just use the electric plug and the extension cord I carry anyhow.
« Reply #4 on: October 23, 2019, 09:42:56 pm »
« Last Edit: October 23, 2019, 09:46:00 pm by donc13 »
dogyard
« Reply #5 on: October 23, 2019, 09:58:03 pm »
Looked at 12V/120V models but figured I've always got electric on-board so decided to go with tried & true....
https://www.aircompressortalk.com/porter-cable-cmb15-150-psi-oil-free-fully-shrouded-compressor-review/
« Reply #6 on: October 23, 2019, 10:29:34 pm »
Hi Gary
I'll probably be of little help to you because after researching things pretty thoroughly I went with the Viair.  Their RV models are a simple build, very high quality unit with a very small footprint (12.5"X6"X7.5").  I actually like the 12-volt battery hookup since it just takes a second to set up. I just pull the compressor out of the rear storage drawer, open the house battery door and slide the batteries out, clip on the clamps and with the 30-foot coiled hose reach every tire on my rig.  The negative is cost--the 400P and 450P kits run from about $200 to $300 depending on the specific kit, but these are nice units--automatic compressors that operate like your water pump--only run when you're actually injecting air and immediately shut off against the pressure in the line if you stop to check pressure or move to another tire.  Be careful of the "ratings".  I bought the 450P, since it is a 100% duty cycle compressor--can run an hour straight if you should need to without cool-down (many small units are 30% duty cycle compressors).  It's a 150 PSI (max) compressor that can actually inflate a tire to 130 PSI if needed (most similar compact units can't).  The 450P-RV kit also has a second 30-foot coiled hose that provides 60-foot reach if you should need it, canvas storage case, and a hand gun with extremely accurate gauge that the screw-on and direct-connect chuck attachments clip to.  All-in-all a really nice unit that should outlive the RV.
After all that, I hear your original comment: "....not to break the bank on something I'll hopefully not use frequently."  That is a reasonable consideration as well!!
All the best with your search,         Mike
DKCruzser
  • 78
  • PurchDate: September 2018
« Reply #7 on: October 23, 2019, 11:55:55 pm »
We also use the Viair.   We agree on Mike's points;  the downside being the cost.  But this is a very reliable compressor as we just found out when heading out for the Charleston rally.   It was nice to have when we discovered that one of our tires on the tow car needed air.  Because this compressor can provide high pressures it works well not only with the low pressure for the tow car but higher pressures that are needed for the tires on the RV.
Dave
2017-2910 D
« Reply #8 on: October 24, 2019, 05:41:35 am »
AWESOME writeup. I am sold.  Getting it through Amazon.
faiello
  • 98
  • PurchDate: 08/2019
  • IntColor: Graystone/Cherry
« Reply #9 on: October 24, 2019, 08:41:02 am »
This is the one I use and have had no issues with it. If it gets too hot it will shut itself off, wait 10-15 minutes and you are ready to go again.
TIREWELL 12V Tire Inflator-Heavy... https://www.amazon.com/dp/B06ZXR9P6R?ref=ppx_pop_mob_ap_share
Frank & Beth
« Reply #10 on: October 24, 2019, 11:50:01 am »
The over-all design and affordability of this Porter Cable compressor intrigues me, but I have some potential show-stopper questions.
Does it have an integrated storage compartment for the hose and accessories?  If not, how are the hose with accessories stored?
Does the hose have a quick disconnect on both ends?  It does not appear to.  It looks like I need to wrench-attach when I want to use it :(
« Last Edit: October 24, 2019, 02:00:39 pm by Ron Dittmer »
« Reply #11 on: October 24, 2019, 01:02:52 pm »
I carry one of these
https://www.amazon.com/Husky-HY120-Inflator-Analog-Pressure/dp/B0085X4IZM
Like garmp said, hope you never use it and have used it only one time to help a fellow camper in a NF campground.   I also carry a 25 foot extension cord.   We just fired up the guy's generator, plugged in my compressor and extension cord and took care of the truck tire.
I bought mine at Home Depot for $25 on sale a few years ago and I saw them on sale there recently.   I tried it on my PC when I first got it and was satisfied it would do the job and it certainly did for the guy with the low tire down the road.   Small and takes up little room.  I just store it in the original box.
Paul
BlueBlaze
  • 158
  • PurchDate: 06/2016
  • IntColor: birch
  • ExtColor: white
« Reply #12 on: October 26, 2019, 01:44:24 pm »
Interesting discussion.  I just carry a little blue $40 compressor from Lowes, but I don't see it on their site anymore.  It says 120 PSI, but I tried to use to air up a low tire on my pickup once, and it took so long I gave up and dragged out my big 20 gallon compressor.  It works fine for inflating the air bags or bicycle tires, though.
Why would you need a real compressor on-board?  Is the idea to be able fix a flat on a 10,000 lb vehicle with dualies at the side of the road?  I think I'd just call AAA.  If I was real desperate, I might try to get out the spare myself and see if that bottle jack I carry is actually any good for 10,000lbs.  But I don't think I'd trust a flat tire plug on such a heavy vehicle, even if I had a compressor that would blow up one of those monster tires.
« Reply #13 on: October 26, 2019, 01:59:10 pm »
blueblaze, I carry one because in past years on other MHs I have had tires with a slow leak, not a flat.  If a tire is only leaking a few pounds a day a small compressor will take care of the problem until you can get where you can have it fixed.   Lots of places we boondockers go don't have cell service to call AAA or Sams.   I do prefer my 120 volt compressor and it will take a truck tire up five pounds in about three minutes.  Hey, I ain't in a rush or I would fly instead of driving. (WH)
BlueBlaze
  • 158
  • IntColor: birch
  • ExtColor: white
« Reply #14 on: October 27, 2019, 08:48:13 am »
Good point.  You're right, I don't boondock, so I just don't worry about 5lbs enough to mess with it when I'm not at a gas station.  But I can see where a slow leak could become a catastrophe if you were parked deep in the sticks for a couple of weeks.  I wonder if most boondockers think to check their tire pressure everyday when they're parked and camping.  Might be an argument for a TPMS, so you can keep an eye on it without losing a pound every time you check it.
