Starter battery disconnect switch
  • 11113 Views
serrano4657
  • 43
  • PurchDate: May, 2019
  • ModelYear: 2006 2551
  • ExtColor: Blue/White
« on: September 05, 2019, 11:13:38 am »
Has anyone installed a battery disconnect switch on there starting battery?    My Phoenix is kept in storage and I thought of adding a battery disconnect switch to starter battery so it won't drain the battery. Will this affect the computer in the engine or erase any engine codes?
Re: Starter battery disconnect switch
« Reply #1 on: September 05, 2019, 12:00:36 pm »
I installed one on mine. It has no ill effects as far as codes or things like a 5 star tune. I installed a Ampper top post knife blade master switch. Cost was roughly $16.00 on Amazon. It’s worked fine all year with no issues.
« Last Edit: September 05, 2019, 12:05:16 pm by Joseph »
« Reply #2 on: September 05, 2019, 02:35:22 pm »
I use these...$6.99 Harbor Freight and elsewhere.
serrano4657
  • 43
« Reply #3 on: September 05, 2019, 04:07:54 pm »
Thanks for the help. I am going to get one now
« Reply #4 on: September 05, 2019, 08:58:46 pm »
Disconnecting the battery disconnects everything including erasing the ECM.  It's not a bad thing to do.  I do it all the time during extended storage.
I had considered getting one of those rotational kill-all switches, but I am concerned about "reliability" over time, especially when the slightest of corrosion sets in.  There is a whole lot of amperage when cranking over the Ford V10 engine.  That would be the worst-case condition to worry about a degraded connection.
BlueBlaze
  • 158
  • PurchDate: 06/2016
  • IntColor: birch
  • ExtColor: white
« Reply #5 on: September 13, 2019, 09:04:13 am »
The FIRST time I replaced my chassis battery, Murphy intervened and chose that moment to strike whichever computer it is that decides when to turn off the under-chassis courtesy light after a few minutes.  So, the next time I tried to start the PC, I discovered that my brand new $100 battery was deader than a door-nail.  I swore to the Costco guy I hadn't left the lights on.  He was skeptical but replaced it anyway.  So I felt like a real jerk when I thought about it, and then discovered the stuck courtesy light.  In addition to unscrewing the bulb, I also added a battery cutoff to prevent anything like that from ever happening again.
As to the reliability of the battery cutoff switch, who cares?  At $10, you can replace it every year if it bothers you.
« Last Edit: September 13, 2019, 07:47:33 pm by BlueBlaze »
« Reply #6 on: September 13, 2019, 09:55:49 am »
I have used 2 Lucky's illustrated switch in all our rigs since the 1990s.  They never caused me any problems and I never had any corrosion problems with them.   They are simple and I love simple.
I bought a new one for the PC and left the old one on my previous rig when we sold it.   Bought it at Walmart for about the price mentioned.
Paul
