Ford Engine RPM Redline
  • 8989 Views
gl1500
  • PurchDate: May. 2014
  • ModelYear: 2551/2014
  • ExtColor: Cafe'
« on: February 02, 2011, 05:02:01 pm »
In talking to Ford mechanics, they  just say there is an electronic RPM limiter and it will cut out power before you exceed the limits.  Could not get a definitive answer on the actual redline.  But, was able to get the RPM where the max horsepower is developed and that is 4250.  Also, able to get the max torque RPM which is 3250.  In our case the torque is the important spec as that is the pulling power we use, especially when pulling a hill.
Re: Ford Engine RPM Redline
« Reply #1 on: February 03, 2011, 10:58:31 am »
I looked on our Vehicle Information sheet for an RPM limiter but nothing listed. There is a listing for an Electronic Speed Limitation device. I don't know if it is one in the same. Our new 2551 was ordered without the Electronic Speed Limitation device.
George
gl1500
  • ExtColor: Cafe'
« Reply #2 on: February 03, 2011, 12:59:29 pm »
George,
    The electronic speed limiter should be to not allow the vehicle to exceed a certain MPH.  They are offering these options to parents to limit the speed their children can drive.  The RPM limiter is built in to either the fuel or ignition system so when the vehicles engine reaches a pre-programmed value, it either takes fuel away or cuts the ignition to keep the engine RPM from over speeding.  In the days before all of our electronics you could over speed your engine and stress or destroy it.
     The statement below is off a site where they talk about Ford problems with technicians.  They talk about both items you referred to.  The governor is the speed limiter, and the rev limiter is the RPM one.
     Hope this helps,  Bob
It is a rev limiter built in to the computer. You can't remove it without a chip.
Don't ask me why, but it's there. I hate it and I also hate the governor that kicks in at 90.
__________________
