Don't bust up your macerator compartment door......
  • 0 Replies
  • 10760 Views
WillLloyd
  • 216
  • PurchDate: Feb/2017
  • IntColor: Pebble
  • ExtColor: Grey
« on: July 17, 2019, 11:34:12 am »
I apparently had the maserator compartment door clipped open on our 2910 when the slide was IN.  Subsequently, I must have put the slide OUT.  Turns out the stupid little clip that holds the door open does a pretty good job, tore the door up pretty bad (body shop bad).
My solution is to remove the clip altogether and just put the screws back in the holes.  I considered gas stuts like the other doors but figured there was a chance the slide would grab the knobs (given my luck).  So I just plan to hold the door open when needed.
FYI....
