Fresh Water Tank Drain Valve Location
  • 9057 Views
jwg1199
  • 25
  • PurchDate: July 2017
  • IntColor: Desert Tan
  • ExtColor: Desert Tan
« on: November 21, 2018, 07:01:11 pm »
We have a 2018 2552. Where is the valve to drain the fresh water tank?
Thanks John
Re: Fresh Water Tank Drain Valve Location
« Reply #1 on: November 21, 2018, 07:23:19 pm »
Lift the mattress on the passenger side, you will see an access panel you can lift and slide to the side.  With a flashlight look inside and you will see the water tank.  Coming out the back of the tank, on the bottom, out will see a short of white PVC pipe and a few inches from the tank, on that pipe, you will see a 1/2 turn valve where the handle will be set so it "crosses" the pipe.   Give it a half turn so the handle is parallel to the pipe.
That will drain the tank.
You may have to move the heater duct (silver foil duct) a little one way or the other to see the valve.
jwg1199
  • 25
« Reply #2 on: November 21, 2018, 09:29:03 pm »
Thanks much! Happy Thanksgiving!
