2005 Phoenix Cruiser Third brake light
  • 1 Replies
  • 8102 Views
OGBILLYT67
  • 1
  • PurchDate: 07/16
  • Model: 2950
  • ModelYear: 2005
  • IntColor: maple wood / off white walls
  • ExtColor: white / gold blue trim and decals
« on: September 26, 2018, 10:43:13 am »
I have a 2005 Phoenix Cruiser  with a third brake light that is out  and needs to be replaced.   Has anyone replaced one of these.  If so where did you get the light?
Thanks
Bill T
Re: 2005 Phoenix Cruiser Third brake light
« Reply #1 on: September 26, 2018, 11:49:45 am »
Hi Bill,
Call the factory.  They might have been using the exact same LED 3rd brake light since they introduced the integrated spare tire wall in 2004.  Make sure to mention it is for your 2005.
If you know how to use a soldering iron, you could remove, disassemble, and inspect the connections and solder joints for cracking or disconnect.  Such an LED lighting fixture can sometimes be repaired.  I have repaired some where I volunteer at an automotive charity.
« Last Edit: September 26, 2018, 11:53:04 am by Ron Dittmer »
