TV HDMI connections....front overhead TV
  • 0 Replies
  • 6727 Views
lamovitz
  • 23
  • PurchDate: June 2014
  • IntColor: Dark Gray
  • ExtColor: Gray
« on: June 09, 2018, 07:55:14 pm »
With changes in watching tv we are no longer using satellite but are going to a roku for internet streaming tv shows.  As such the problem in our 2910T (2015) is that there is one hdmi coming from the front tv thru the right front cabinet and to the dvd player.  You are unable to use the dvd player streaming functions without a wired internet signal (the tv is not internet ready).  So I have taken that hdmi and plugged into a roku player and it works great.  However that means taking out the dvd player or switching back and forth.  It would be great to run another hdmi cable from the back of the tv so that both the roku and dvd player are always available.  The problem is how do you access the back of the tv (which does have a second hdmi input) as the tv is fixed to the front.  I see in the right cabinet next to the tv three screws to i assume open the side panel and gain access to running another hdmi.  However i read a post that those three screws actually hold the tv in place along with three screws in the left cabinet.  Does anyone know how to get access safely to the other hdmi input on the tv.
thanks!
