4way valve problem
  • 27 Replies
  • 31266 Views
Funseekers
  • 50
4way valve problem
« on: March 19, 2018, 11:05:45 pm »
Has anyone heard any news about when the new 4 way valve will be available for installation?
Our second valve replacement has once again failed but fortunately we were able to turn off the outside city water supply before our coach once again flooded.  Am looking forward to this new design that has been talked about as it’s becoming inconvenient to turn off our outside city water at night before bedtime and rely on our water pump (quite noisy for the neighbors)
Am curious if PC is informing new owners of this ongoing problem.
Re: 4way valve problem
« Reply #1 on: March 20, 2018, 12:32:21 am »
First I've heard of it.  What is the make and model of the valve you have?
Free2RV
  • Gary and Susie
  • PurchDate: P.U. 6/11/18
  • ExtColor: Graystone (FBP)
« Reply #2 on: March 20, 2018, 05:43:37 am »
What is the problem with the valve?  Obviously it is leaking for you, but what is leaking; the valve itself, the fittings, etc.?  Thanks for any information.
Gary
TallPine
  • 13
  • PurchDate: 09/2017
« Reply #3 on: March 20, 2018, 09:39:18 am »
We took delivery of our new PC last week and asked specifically about this issue based on previous discussions on the forum.  Was told to relieve pressure before making a switch to another position.  For example, if connected and using city water and wish to switch to tank fill, first turn city water off, open one end of the hose to relieve pressure, switch to tank fill, and then re-connect hose and fill tank.  If the pressure is not relieved, it could damage the O rings in the water switch.  In this example not sure if that also means to open up a faucet inside the coach to relieve pressure from the inside as well.
Hope this helps.
« Reply #4 on: March 20, 2018, 11:17:24 am »
Yes, that is the standard advice for any of these 4 way valves.  And not doing so has apparently caused problems for a long time based on reports on other forums (not just Phoenix).  Search for "kant leak problem".
Typically the valve in question has been from Anderson Brass:
http://andersonbrass.com/rv_4_function_fill_station.php
http://andersonbrass.com/rv_water_service_panels.php
Heartland 200-RV Manual
But I was wondering if that is what Phoenix is still using or if this is a new issue.
RKS
  • 88
  • PurchDate: 1/2016
« Reply #5 on: March 20, 2018, 08:24:28 pm »
Contact Anderson as they were sending at no cost a supposedly updated valve. I received one last year and the leaking has stopped to date.
Bob and Michele
Funseekers
  • 50
« Reply #6 on: March 20, 2018, 10:06:26 pm »
To all who took the time to respond, thanks.
First to Jatrax, it’s the Anderson 4 way valve
Second , it’s not leaking...it’s gradually filling the fresh water tank on the city fill position to the point of overflowing the fresh water tank into the coach
Third, it’s been on city fill only and we aren’t using any of the valve positions
4th, why who would you have to relieve pressure anytime you used other valve positions? Does that really make sense to you if the valve was manufactured properly?
5th, Dave Ponsler has really shook up the tree with Anderson and they are in the process of manufacturing an all brass valve that Dave will sign off on if it corrects the problem.
6th, We were in the same position as others when we brought up concerns about this before purchasing and were told it was “taken care of”.....right!
« Reply #7 on: March 21, 2018, 08:17:12 am »
You said “it’s not leaking...it’s gradually filling the fresh water tank on the city fill position to the point of overflowing the fresh water tank into the coach”.  We have had the leaking into the fresh water tank when on city water. If it fills the tank it overflows out the hose fill plate on the passengers side to outside rather than into the coach.  Is your FW tank overflow hose connected and working without leaking?
We had our 4 way valve replaced at the factory last year and seems to be working properly now.
Funseekers
  • 50
« Reply #8 on: March 21, 2018, 10:41:38 am »
That is a good question to address when I work on the coach today....thanks.
JHoecker
  • 30
  • PurchDate: May 14 2019
« Reply #9 on: March 23, 2018, 05:36:25 pm »
I just watched the 57 minute 2552 Walk Through, and Kyle points out that you CAN switch from city water to tank fill directly - no mention of removing hose and de-pressurizing before switching functions.
Funseekers
  • 50
« Reply #10 on: March 28, 2018, 10:02:06 am »
Ideally that is how it should have worked but apparently it hastens the failure of the unit.  As an aside, going through the machinations of de-pressurizing would certainly indicate the valves inherent design flaw and apparently Anderson agrees which was the point of my original post.
« Reply #11 on: March 28, 2018, 11:43:19 am »
They do not all fail so it would seem that process is OK 'most' of the time.  So some other factor comes into play that causes the failure on some units.  Might be only when used above a certain pressure, or perhaps the o-rings lost lubrication or a bit of sharp edge in the valve that cuts the o-ring when the pressure is above a certain point.  Or some other factor or combination.  Regardless it seems that turning the valve with the pressure off reduces the likelihood of failure.
There is a bit in the manual about lubricating the o-rings with Dow Corning 111 food grade grease.  Here is another link I found: Installation and testing
« Reply #12 on: March 31, 2018, 07:57:31 pm »
This discussion got me a little worried about the valve on my rig so I went out today to do a walk around and checked the valve while I was there.  It was extremely tight and the amount of force required to turn it was surprising.  This is with no water pressure as the rig is winterized.
So in the interests of preventative maintenance I decided to pull the cartridge and check the grease on the O-rings.  The first two attempts failed but after checking the Anderson website I found a video that explains the process well.  Oddly on mine the little set screw they show was already loose and stripped so it could not be tightened.  Anyway, i followed the video process and pulled the cartridge, I see no damage to any of the O-rings.  I applied a liberal coat of Dow 111 food grade grease and put everything back together.
The valve now turns with hardly any force.  From that I assume something was dry and the addition of grease has improved the situation.  I will not know for sure until I de-winterize and can check while in operation.  I plan on adding this to my annual maintenance list.  I'm not sure it is needed but if it helps it was a simple 10 minute job once I figured it out.
Bill G
  • 53
  • The Midnight Rambler - Andersonville National Cem.
  • PurchDate: November 10 2016
« Reply #13 on: April 01, 2018, 04:30:02 am »
So where does one get Dow 111 food grade grease?  tymote
Bill G.
Free2RV
  • Gary and Susie
« Reply #14 on: April 01, 2018, 06:27:27 am »
Amazon carries it in small tubes and other types of containers.  Sounds like a good time to lubricate the O rings would be right after winterizing the system so the O rings are not dried out throughout the winter season.  Like Jatrax said, that will be added to our winterizing procedures.  That way it will be ready for the next season.
Gary
