rain leak
  • 1 Replies
  • 8755 Views
campergates
  • 25
  • PurchDate: 05/04/2016
  • IntColor: sand
  • ExtColor: sand
rain leak
« on: February 06, 2018, 09:18:53 pm »
I have rain leaking through the headliner over the windshield on the passenger side of my 2016 2351.  I climbed on roof but could find no entry point - such as bad caulking.  Would appreciate any ideas? :'(
ron-n-toni
  • 191
  • PurchDate: 8/3/2017
Re: rain leak
« Reply #1 on: February 07, 2018, 09:38:00 am »
I had a 2016 2351 and can only think of three things that may cause a water leak. 1) the tv antenna. recaulk the heads of the mount screws and where the mounting plate meets the roof. make sure the boot on the wire is down and tight. 2) the front cap seal. If it leaks while driving, it could be blowing under the cap seal. You could take the front tv and paneling out to get to the screws but caulking would work. Try to slide something thin between cap and chassis roof.
3) the front roof vent. Caulk all screw heads and check caulking around the vent to roof seal.  Remember, water "travels" and the smallest pin hole will cause a leak. Hope this helps.
