Tuning-Up Your Heavy Duty Stabilizer Bars
  • 18407 Views
« on: December 03, 2017, 08:35:40 am »
I had a rattle in my front suspension for a few years now.  This year it had gotten worse.  Yesterday while putting my rig away for the season, I decided to take a serious look at what might be the issue.  It turned out that my front heavy duty Roadmaster stabilizer bar two end-links had become loose.  There is a U-shaped bracket used like a washer, on the bottom of the end-links that was rattling against the lower connecting bracket.  Tightening the top and bottom end-link nuts, tightened the bushings snug again and I consider the problem solved.  I did not test drive our rig afterward.  I'll find out next year if that eliminated the rattle noise, but I am confident it did.  Rattling or not, there should never be any play in the end links.  I consider the process a stabilizer tune-up because loose end links render the bar less effective.  In the spring, I'll be checking my rear bar for the same.
This picture shows the end links.  They are the vertical bars with a curvature to them with blue bushings top and bottom.  You can see the black U-shape bracket working like a washer, on the bottom of the end links that made the noise.  That black metal bracket/washer was loose and rattling against the shinny bottom metal bracket.  Both top and bottom nuts needed tightening for proper adjustment.  While tightening, I made sure the curvature of the end link curves away from the adjacent steering linkage.  Because my end links were loose, the vertical bars spun freely leaving me to wonder if they occasionally made contact with the steering linkage.
Here you can see the U-shape washer at nearly 90 degrees from the previous picture
You can inspect your Roadmaster front stabilizer bar in just a few seconds.  Get under the front of your RV and make sure the end links curve away from the steering linkage, curving rearward.  Also grab the black U-shaped bracket washer and see if it moves freely.  If either are not right, you have some simple work to do.
« Last Edit: December 04, 2017, 08:28:33 am by ron.dittmer »
jimmer
  • 156
  • PurchDate: 5 / 2016
  • ExtColor: WHITE OVER BLUE
Re: Tuning-Up Your Heavy Duty Stabilizer Bars
« Reply #1 on: December 06, 2017, 10:02:30 am »
Well done,  Ron.     Not an easy place to take pictures !     Just wondering,  are those nuts in question of the  locking type ?    Or should  'Loctite'  be used  ?
« Reply #2 on: December 06, 2017, 10:39:12 am »
You ask a good question.  It surely would not hurt to use Loctite on them.  I did wonder if the play was not just from coming loose, but also from wear-&-tear on the blue polymer bushings themselves.  Maybe the wear-&-tear introduced enough play to start the loosening-nut process.
One thing I did pay attention to.  The nuts never did spin freely.  They always had some resistance when tightening them.  They might be the locking type, or maybe there was just some corrosion causing that.  The nuts did not have the nylon locking feature.  They might have the "dimple locking" feature but I didn't study them for that.
The pictures were taken 10 years ago.  The suspension doesn't look much different today given our seasonal use and storage, just 35,000 miles of additional road grime.
« Last Edit: December 06, 2017, 10:48:33 am by ron.dittmer »
