3" sewer hose
  • 13 Replies
  • 31600 Views
garmp
  • 354
  • PurchDate: 3/20
  • ModelYear: 2020 2351D
  • IntColor: Greystone
3" sewer hose
« on: October 26, 2017, 04:53:36 pm »
With the mercerator system as standard equipment on PC's, does anyone carry a 3" sewer hose? What length? and why?
Thanks
Re: 3" sewer hose
« Reply #1 on: October 26, 2017, 05:05:33 pm »
I carry a 20’ hose that I use when we are staying more than a couple of days. I leave the gray open until just before I need to dump the black. Then I dump the black real fast, moving all the solids out much better than the slow moving Mercator does. After closing the black, I open the gray again and don’t have to think about dumping for several more days. The big hose dumps faster and a lot quieter.
Some people say that allows gas into my RV. Not so as I leave a lower section of the hose between the RV and the ground hole, forming a block like a “P” trap works. I don’t use those slinky ramps. Even if gas was to get into the tank, it would just exhaust out the top vent on the roof.
That is just my way of doing things and I am sticking to my way.
Carol
  • 303
    • Aging on Wheels
  • PurchDate: July 2014
Re: 3" sewer hose
« Reply #2 on: October 26, 2017, 07:32:37 pm »
I carried the basic Rhino 3-inch hose kit in its box just in case I ever needed it.  When I bottomed out my driver's side rear and broke the seal where the macerator attaches to the rest of the stuff back there, I was very happy to have that kit available.  After someone helped me get the macerator out, I decided to just use the manual dump method until the next time I was in Elkhart, at which time I would decide whether to get a new macerator installed or simply continue with the low-tech method.  After six months of manually dumping, I did not miss the macerator once.  So when I did get to Elkhart, they helped cut out and dispose of the tubing and that way I could fit my Rhino hose in that compartment.  (In addition, I have a 10 foot extension hose, if needed, although I have never used it.  I do not camp hooked up to sewer, though.  If you do, then that extension may well be helpful.)
Fast-track back four years to when I was exploring what RV to buy and what options to get, I was never a fan of the macerator.  It looked like one more thing that could go wrong and that I could not fix and that would be really nasty if it happened to go wrong at a bad-black-dumping moment.  Phoenix had it as a standard item, though, so I took it.  In hindsight, I would have asked if it was possible to set the rig up for manual dump from the start.  Just my two cents.  :-D
RheaNL
  • 220
  • PurchDate: October 4, 2012
  • IntColor: Dusk
  • ExtColor: Dusk lower
Re: 3" sewer hose
« Reply #3 on: October 27, 2017, 10:03:06 am »
Absolutely carry one.  First time you crack or jam the macerator you will be glad for the extra equipment. We have a 2100 so not much storage but still considered it essential.
Like Carol, we dry camp a lot in national forest and on BLM land so don't stay connected.  Broke the macerator twice and it jammed once between the two breaks. After the second time, I disconnected the macerator, removed all the parts in the side compartment and store a 10 ft. 3" hose and flushing hose in there. We carry a 10 ft. extension in with the spare tire should we need a longer hose. Increases the process a few steps, but overall way less hassle, at least for us.
Re: 3" sewer hose
« Reply #4 on: October 27, 2017, 06:00:00 pm »
I have a Rhino hose rolled up in the trunk, tucked back in that area that isn't too useful anyway.  Never used it, still in the plastic.  But it's there if I ever need it.
One tip I learned at the Phoenix Club rally was that even with just the macerator hose you can open the gray valve and leave it open if you are staying long.  If it doesn't drain at first go out and bump the macerator pump on  for just a few seconds to get it flowing and it will siphon on its own after that.  Shut the gray valve the day before you leave to fill the gray tank and then flush as normal.  Worked great for me.
Re: 3" sewer hose
« Reply #5 on: October 28, 2017, 06:40:32 am »
We have a Rhino hose which is stored with the spare tire on the rear of the Phoenix.  We carry it for emergency use and found the 3” hose very helpful when we developed a small hole in the macerator hose.
After stopping the leak in the macerator hose we returned to using the macerator which I much prefer.  As stated above when in campgrounds with sewer connections we typically leave the gray water valve open if we will be staying multiple days.
I am not sure of the difference in pumping rates between the older and the newer “Turbo” model but I find the Turbo to very quickly dump both tanks and it is more convenient not to have to connect and disconnect and rinse the Rhino hose.  Haven’t measured the difference in dump times between the macerator method vs. the 3” hose but I doubt there would be much difference (the macerator may actually be quicker).  I am always impressed how quickly the Turbo macerator empties the tanks.  As in most things having a backup plan is wise and thankfully I had the Rhino when I needed it.
« Last Edit: October 28, 2017, 08:22:58 am by fandj »
Two Hams in a Can
  • 248
  • Model: 2400 Sprinter
  • ExtColor: Rust
Re: 3" sewer hose
« Reply #6 on: October 28, 2017, 08:27:00 am »
This is our first experience with using a macerator in almost 20 years of RVing in four different RVs, and we love it (not having any breakdowns so far-knock on wood).  As far as time in dumping, we both have our getting underway jobs, and it doesn't take (for me) any more time than getting out the 3" components, dumping, washing out and storing at a fhu site.  While at a dump station, DW usually sets up the GPS while I'm pumping, so time is used efficiently.  We do carry a 10ft 3" hose in the spare tire compartment just in case.
Side note-When the rare occasion arises that we get home and park Fawkes in the driveway still containing a small quantity of black tank contents; we merely run a dedicated 50ft garden hose down to the basement bathroom (lucky us) and pump and flush away.  Couldn't do that with a 3" setup as we had dealt with in the past.  Happy trails. . . :)(:
garmp
  • 354
  • PurchDate: 3/20
Re: 3" sewer hose
« Reply #7 on: October 29, 2017, 04:12:26 pm »
Sounds like a 3" hose set-up is a must. Just wish the shower in a 2100 was a bit larger. After storing the leveling blocks, other misc gear and now a box of 3" sewer hose components, room is getting full. Just hope we don't get dirty. :-D
Two Hams in a Can
  • 248
  • ExtColor: Rust
Re: 3" sewer hose
« Reply #8 on: October 29, 2017, 07:23:53 pm »
We had a similar storage crunch, especially with my Pride Mobility "cripple cart"; so we got this.  LUV IT!  https://www.amazon.com/gp/product/B001G4Z5J0/ref=oh_aui_detailpage_o03_s02?ie=UTF8&psc=1        :)(:
Re: 3" sewer hose
« Reply #9 on: October 30, 2017, 12:37:40 pm »
If your PC has a spare tire mounted on the rear of the coach you can probably store a 10’ collapsible Rhino hose inside the fiberglass that covers the spare tire.  That is what we do.  If we used the 3” hose exclusively we would look for a more convenient place to store it but since we only use it should something happen to the macerator system it is a good out of the way storage location.
« Last Edit: October 30, 2017, 04:56:48 pm by fandj »
Cropduster
  • 124
  • PurchDate: 05/2015
  • ModelYear: 2002
  • IntColor: Brown
  • ExtColor: Brown
Re: 3" sewer hose
« Reply #10 on: December 25, 2017, 01:14:13 pm »
Your favorite home/hardware store will have straight pipe with the necessary diameter to handle the sewer hose.  Of your 2100 you can attach this pipe under the rear bumper or under the vehicle (but where it is accessible).  Don't forget the cap ends.  With the farthest end cap glued permanently in place.   Threaded or press fit on the near end.  Use a line to secure this cap so it cannot be lost.
Dave
  • 48
  • PurchDate: January 2015
Re: 3" sewer hose
« Reply #11 on: December 27, 2017, 07:58:17 am »
we keep the 3 in h hose in a plastic trash bag in a plastic tub in the back of the crv. easy access, no odor.
Re: 3" sewer hose
« Reply #12 on: December 27, 2017, 12:02:30 pm »
Hi All,
I hope the Phoenix family all had a wonderful Christmas celebration.
A long long time ago, I bought one of these but never got around to installing it.  It seems there is a good place behind the rear axle of our 2350 to hang it below.  I have the typical Rhino Sewer Hose system that stores perfectly inside it.
It is not nearly as durable as a standard PVC pipe so I can't endorse it.  I would feel much better if it was made of thick strong PVC pipe.  Given what I know today, I would make one from PVC pipe.  This thing seems too frail for hanging behind the rear axle where stones and such could pelter it.
« Last Edit: December 27, 2017, 12:19:07 pm by ron.dittmer »
dickreid1
  • 163
  • PurchDate: Feb. 2012
Re: 3" sewer hose
« Reply #13 on: December 27, 2017, 11:33:44 pm »
The Rhino hose was one of the first things I added when we bought the coach.  Had to use it last summer.
Next was a Progressive Industries electrical management system. It has protected us several times.
The following year I added jumper cables so I could start the engine from the house batteries.  So far so good.
