Storm Report Aunt Irma
  • 1 Replies
  • 7653 Views
HenryJ
  • All ready for the road
  • ModelYear: 2016 / 2910T
  • IntColor: Hickory (light)
  • ExtColor: graystone
« on: September 10, 2017, 01:54:38 pm »
I drove the PC up to park by the house. Driveway is higher ground that where we usually park with elec avail ... no elec at the house yet.
So I fired up the genset for an hour so that onboard batteries are holding their own. We have a forecast of elec power in house to be
off later. With Genset in RV we can have coffee and toast no matter as long as it remains in place in the driveway. We've had heavy rains a while ago.
Did squeeze a short visit out for Miss Elle... she was more into sniffing than worrying about the weather.
I tried wiping down the drip from AC by the drivers side door with CLR on a cloth and it did help remove the drip lines which were awful. I had tried other cleaners but that was only one that made a dent in the lines. I think it needs an extension on the drain so it does not run down the side but that is after the bad weather passes. And should be thoroughly cleaned and waxed then it might not stain so . PWS
Patricia
hutch42
  • 246
  • ModelYear: New TRX
Re: Storm Report Aunt Irma
« Reply #1 on: September 10, 2017, 11:54:47 pm »
Good luck with the storm.   My sister lives in Palm Harbor.  They were trying to figure out how to tie down the screen house over the pool.   At least you got your PC for creature comforts.
