2 AC units in a 2552
  • 31 Replies
  • 33721 Views
Thomas4854
  • 60
  • PurchDate: August 14, 2017
« on: April 26, 2017, 08:31:16 am »
Are 2 AC units in 2552 really close together? Noise factor is the main reason we're considering 2 vs 1 larger unit. Appreciate input from owners with 2 units. Thanks.
Re: 2 AC units in a 2552
« Reply #1 on: April 26, 2017, 08:52:44 am »
Last September while in Myrtle Beach (sitting in the direct sun) our standard unit was having problems with the heat and humidity. It was so bad I had the local "at site service guy" look at it. He said it worked better than the new unit he had just installed on my buddies 5th wheel. I sure wish I had two units for day time use. I would use just the front unit at night. Keep in mind that if you close the door to the bedroom, you are closing off the air flow also. Then you might want to use the rear unit at night. I will say that way back in time I was in the Navy and learned to sleep through anything. So a/c units don't keep me awake.
randallandchris
  • 127
  • PurchDate: June 2015
« Reply #2 on: April 26, 2017, 10:50:16 am »
Even the larger A/C on our non-slide works really hard when hot and humid and the fan is super noisy so that we have trouble hearing the TV.   If the smaller unit is quieter and can control 2 of them independently then would be great for the big PCs with slides and am sure they can be put almost anywhere you would want.
« Reply #3 on: April 26, 2017, 11:05:07 am »
I have only the single larger unit, which has never worked so I have no idea how much noise it makes :)
But I have seen a number of posts on this forum stating that the smaller units actually are noisier than the larger unit.  Of course that is subjective, and a change in brand or model over the years might have more to do with the difference than just the size.
The biggest advantages I see of having two units are 1) duplication, in case one unit fails you can still operate until repairs are made and 2) if you run the front unit when you are in back and the back unit when you are in front, it MIGHT make the noise seem less and 3) if you need the additional cooling in hot humid climates.  I believe the large unit is 15k btu and the smaller ones 13.5k btu so two units have a much larger capacity than a single large one.
We went with one unit because we wanted solar panels and needed the roof space.
« Reply #4 on: April 26, 2017, 11:14:05 am »
No matter what, air conditioners are loud.  I have had both ducted and unducted units.   The only a/c I have ever heard thar is quiet are in class A motorhomes where the a/c is in the 'basement'
Two is always better than 1.  The 13,500 BTU in our 2551 simply can't keep up when the temp gets over 87 or so.  I wish I had 2 of them. That way I could keep the fans on low. For my 2551, I am sure that'd be plenty.
Understand, you'll need 50 amp (220v) wiring and the generator will only run one of them.
My last RV had a 15,000 BTU a/c in it, that RV was a bit smaller than my PC and it had the same issue when it got higher than 87 or so outside.  So I don't think that's the answer.
Just my 2 cents.
« Reply #5 on: April 26, 2017, 02:11:34 pm »
As far as location of two units on the 2552 I believe one is along the centerline and between the microwave and pantry, the other along the centerline between both beds close to the bathroom door.  Not a huge distance apart, but the two different 'rooms' they serve would provide some noise baffling between the two.
I've tried researching noise levels of different models from different companies and found precious little regarding technical specs or advertised sound levels (actual decibels) Different designs of different brands at different times can have significant impact on noise.  Noise can emanate from motors, fan blades, etc.  On the Coleman Mach 8 15,000 BTU unit, which I have, there were changes made to the fan blades over the recent years which reduced noise.  On other companies units, the diffusers were recently redesigned to reduce noise.  Personally, I think the diffuser makes a huge impact on noise.  Trying to disperse and divert air by pushing it over fins and flaps creates a racket (remove your ceiling diffuser and see the difference)
Knowing as much (or as little) as I do now, I would have specified two non-heatpump units (one 13.5k and one 15k btu) with high CFM rates (they apparently range from 275-350 or so), multiple fan speeds and well engineered diffuser/motor/blade designs.  For us, very low roof profiles (like our Mach 8) or savings of a couple hundred dollars (Dometic) are not as important as good performance and reduced noise.  We like nice sunny weather but aren't terribly comfortable at temps over 100 degrees or at very high humidity levels, so two units would have made us much happier.
« Reply #6 on: April 26, 2017, 03:22:50 pm »
On the 2552 you could have 2 A/C units 10' apart. Use front where the vent is now and the back where the Fantastic fan is.
The Fantastic fan could go where A/C is now.
Plenty of room as long as you don't need roof for anything else.
I only camp in the winter and almost never run our A/C at all, but I like it hot.
« Reply #7 on: April 26, 2017, 06:25:57 pm »
Just for the record for people who wonder about the 2350 with no slide-out.  The standard a/c unit works great in over 100 degree temps, but you have to do well at blocking out the sun in the cab area, and use your awnings to keep the sun off the thermal pane windows.  Depending on how bad the heat is, you may have to sacrifice the bathroom.  Keep that door closed and let it cook in there.
And don't be opening the entry door all the time.   :)
Thomas4854
  • 60
« Reply #8 on: April 26, 2017, 06:44:36 pm »
Keelhauler, your idea is exactly what we decided on talking to Earl today! Great minds think alike, I hope. BTW, we lived in Avon, Ohio 2003-2008 before moving back south.
Thank you for the input everyone. Planning on finalizing this tomorrow so I can move on and worry about other things. 😬
« Reply #9 on: April 27, 2017, 06:52:03 am »
"Other things" - all the cool RV/Camping toys and gotta have items to go IN your new RV. Enjoy the anticipation!
« Reply #10 on: April 27, 2017, 11:38:18 am »
I love to read the excitement of new owners ordering their PC "Just Right" for them.  Enjoy your research Thomas!
Capt Ron
  • 3
  • PurchDate: 05-14
  • IntColor: earth tones
  • ExtColor: grey/black/silver
« Reply #11 on: April 30, 2017, 03:24:07 pm »
I recently added a 15000 BTU AC to my 3100.  needed also to ad an additional 30 AMP ckt.  The new unit is very quiet and cools the entire coach. Camping world charged us about  $2k for the wiring ,unit and install. Very happy at we have two AC units. We live in Florida.. It is already over 90 degrees and its only April.
Cat House
  • 40
  • PurchDate: 17 Oct 2016
« Reply #12 on: April 30, 2017, 05:44:10 pm »
Hey Thomas 4854!  We are in Spanish Fort when we are home.  Have had the new to us 2552 PC since Oct and love it. If you want to get together give us a shout.
Marilyn, Tom and the three traveling cats.
Thomas4854
  • 60
« Reply #13 on: May 01, 2017, 10:34:58 am »
Cat House, I sent you a PM.
« Reply #14 on: May 03, 2017, 10:44:08 pm »
Capt Ron, 2 grand sounds reasonable to me considering the wiring etc.  What brand and size unit did you have installed?
