Coleman Mach 8 air conditioner not working
  • 12562 Views
4X4Diversion
  • 14
  • PurchDate: November 1, 2016
« on: April 03, 2017, 04:29:34 pm »
My husband picked up his brand new 2351 Phoenix Cruiser in November of 2016.  Last week on a trip we used our air conditioner for the first time.  It worked for approximately an hour, then it started to make a low frequency hum.  We noticed when it made the low frequency hum the lights in the RV dimmed.  The air conditioner no longer puts out cold/cool air.  We have a Coleman Mach 8 15000.
Does anyone have any ideas on what is going on with the brand new air conditioner?
Pattee
Two Hams in a Can
  • 248
  • Model: 2400 Sprinter
  • ExtColor: Rust
Re: Coleman Mach 8 air conditioner not working
« Reply #1 on: April 03, 2017, 05:14:11 pm »
JMHO. . .it sounds like you might give Kermit at the factory a call since your PC should still be under warranty.   :)(:
« Reply #2 on: April 04, 2017, 07:43:44 am »
Pattee:
We had an immediate problem with our Coleman unit when we received our PC as well.  A quick call to Kermit got us authorization to bring it to our local RV service center (we tried changing out the thermostat ourselves, which turned out not to be the problem). The issue was a loose connection (wire nut) on the rooftop unit.  All has been well since.  Your problem may be different, but hopefully it is as easily resolved.
Joe R
  • 39
  • PurchDate: Jan. 2015
  • ModelYear: 2004
  • IntColor: gray, maple trim
« Reply #3 on: April 04, 2017, 09:34:54 am »
If the low frequency hum lasts for only 3to5 seconds and stops for 10 to 15 seconds and then repeats. First are you using a long extension cord along with the electrical cord that came with the PC? When the compressor on the air conditioner goes to start. There is a momentary  drop in the voltage. If you  use a light duty extension cord its like using a hose the size of a straw to put out a fire. On start up the voltage could drop as low as 60 to 80 volts. Which is not enough to start the compressor. ( this is also why you see the light dim)
Now if the voltage delivery is adequate we need to look at a few things in the air conditioner. First there is a start capacitor, you always get a certain amount of voltage drop when a high torque motor starts. A start capacitor is a storage compartment for voltage. When the motor starts it is normal for the voltage to drop to around 90 volts. This is when the cap is allowed to discharge and keep the supply near 120 volts.
Next there is a relay that provides voltage to the start windings of compressor momentarily to get the armature spinning.
Now to the most costly part, the compressor. the compressor has to sets of windings, a start and a run winding. Like its name the start windings are energized momentarily by the relay. Once the motor starts to turning the start windings are dropped and only the run windings are left energized. Then the compressor could be seized up.
Any one of these can cause the symptoms your experiencing . Oh and I forgot to mention the circulating fan motor. But my bet  would be a cap or compressor.
4X4Diversion
  • 14
« Reply #4 on: April 05, 2017, 08:02:39 pm »
Thanks everyone for your input -- they give me some ideas about what could be wrong and what needs to be checked on our A/C.
Pattee
Joe R
  • 39
  • ModelYear: 2004
« Reply #5 on: April 06, 2017, 07:04:27 am »
Let us know what they find.
