Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Guest
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
Factory installed valve extenders
« previous
next »
Pages: [
1
Go Down
Badger
3
PurchDate: 8/2015
Model: 3100
ModelYear: 2015
IntColor: grey stone- cherry
ExtColor: grey stone
on:
February 14, 2017, 04:59:21 pm »
Has anyone had the factory replace the valve extenders on the dual wheels? I have a 2015, 3100 & have had my share of grief with these. Not a new problem with flexible extenders just wondering if anyone has found a reliable solution.
Badger
1165
PurchDate: 10/17/11
Model: 2551
ModelYear: 2012
IntColor: Cherry
ExtColor: Classic Umber
Re: Factory installed valve extenders
Reply #1 on:
February 14, 2017, 07:44:58 pm »
Badger,
Here is a link to what we did two years ago
http://forum.phoenixusarv.com/index.php/topic,2080.msg16401.html#msg16401
We are very pleased with these. They have held solid with no air leaks in the two years.
Current 2012 2551 w/Slide
345
Model: 2552
ModelYear: 2016
IntColor: Graystone
ExtColor: Nightscape - full body
Reply #2 on:
February 14, 2017, 08:25:19 pm »
I replaced the the PC provided dually valves with Borg brand valves. So far the Borg valves have performed excellent. They allow easy pressure checks and adjustment of tire pressure to suit ambient temperatures. Also they hold pressure without leakage. I also have the TST tire pressure/temperature system that provides constant monitoring and alerts if either pressure or temperature goes outside programmed limits.
Tire Man valves are also a popular valve brand to replace the flexible style and other valve extensions. Both Borg and Tire Man are one piece in that they do not require extensions.
I purchased the Borg valves online and had them installed at a local tire shop. I did not ask Phoenix to replace the valves prior to delivery. I do not know this but I assume the valved wheel/tires are supplied by the chassis supplier. Kermit provided me the name of the extension supplier so I assume PC purchased and installed them.
gandalf42
221
PurchDate: May.2017
Model: 2552
ModelYear: 2017
IntColor: Hickory/Graystone
ExtColor: 2 Tone Graystone/Nightshade
Reply #3 on:
February 14, 2017, 08:53:46 pm »
On new units PC has gone away from the woven flexible extenders to solid metal extenders (per Earl)
Mike & Pat Astley,
hutch42
246
OwnPC: No
PurchDate: Interested in the new Ford Transit Diesel models
Model: 2100
ModelYear: New TRX
Reply #4 on:
February 16, 2017, 12:16:34 am »
Heres an option. This is the go to guy on the west coast for solid valve stems. Recommended by "Lazy Daze"!
Not sure who has been around longer, probably Lazy Daze. People swear by them.
http://tire-man.iwvisp.com/
Pages: [
1
Go Up
« previous
next »
