Spare tire, galley storage, LP solenoid, "Sticky Feet" for solar panel mount
  • 9846 Views
sailors35
  • 94
  • PurchDate: May, 2017
  • ExtColor: Desert Sand
As we anxiously await our 2351 we are filling up our question bank.  Thought we would combine a few.  Need not respond to all, but always welcome to-
1.  Co-captain is interested in how folks store pots and pans in galley.  (2351 with dinette and slide)
2.  New models do not have spare tire, appreciate thoughts.
3.  Has anyone used "Sticky Feet" solar panel mounts that use 3M VHB tape rather than drilling holes in roof.
4.  Backer board in rear storage.  We plan on designing our own layout, but still not sure what the factory means by backer board.  Is it the small board on the exterior face or is it plywood behind the panel in the compartment? tymote
Mike & Lynn Ratliff
2. That is a concern of mine as well.  But then I consider it is highly unlikely I would be in a situation where I would change the tire myself, I'm not going to worry about.  Too much.
3. No experience with it, but check some of the solar boards and it seems fairly common.  Must be some really tough tape.  I prefer screws and Dicor.
4. My understanding is that is additional (plywood?) behind the decorative thin exterior.  But that is just my understanding.
Jjohnson
  • 9
  • PurchDate: march 2017
  • IntColor: desert sand
  • ExtColor: desert sand
I can only comment on #2 .  It seems to me with dualies on rear you could remove a tire and put it on the front so you could limp to the nearest tire dealer. Not so with srw on the rear where you can try to plug it or wait for someone to bring you a tire. Need a spare if you drive with single rear wheels or good sam, AAA or whatever.
In response to your #3 question - I installed a solar panel to a previous unit using 3M VHB tape.  The shell of the unit was constructed with molded fiberglass.  I used the camper for four years before I sold it and never had an issue with the attachment.  This type tape is used to secure panels to ambulances, trailers, and aircraft so it has a proven track record.
However, when we ordered our PC I elected to have Phoenix install the panels on my 2552 as I was somewhat concerned that the textured surface on the PC roof may not be as good a surface to bond to as the smooth surface as my previous unit.  Secondly, I was told by PC that if solar panels were to be installed that plywood stiffening/anchoring panels would be added in the area where the panels mount. Thirdly,  I trusted PHoenix's knowledge and experience in mounting the panels as I didn't want risk of the panels coming loose by relying on the tape bond to an unknown substrate.
I have inspected the panel mounting on my 2552 and everything appears to be holding up well.  As in all caulked areas I know at some point it will probably need recaulking.  It appears the factory used Dicor self leveling sealant over and around each attachment bracket foot.
gandalf42
  • 221
  • PurchDate: May.2017
  • IntColor: Hickory/Graystone
#2 Spare Tire: Still an available option on some shorter units, 2552 and smaller.
With a cautious, "be prepared" mentality a spare tire is important to me. With my current Born Free I first went the route of putting a mounted spare on the roof ratcheted down to the luggage rack. The problem is getting the heavy tire up and down. I even tried using a small winch but still too big of an effort and the tire would hit/rub against the RV on the way up.  >(
I next went with a front hitch mounted tire carrier. This has worked well and also had the benefit of canter-levering the weight from the back axle to the front axle, improving the ride.  :) The down side is that it blocks some of the air flow to the radiator. Hasn't been a problem until the RVhas gotten older and starting to run a bit hotter.
I think the PC rear mounted spare is a good option.  2o2
So what has been my experience in needing a spare? Well, over 10 years and 90,000 miles fortunately I have had only one flat. Since that was in Nicaragua I was happy to have a spare to use! No flats in North America. The repeated challenge has been with leaking valve extenders.
After having one in the Yukon where I had to travel 200 miles on a leaking tire before I could find somewhere to even put air into the tire let alone fix it, I learned my lesson to only use good extenders, carry a good air pump. and because of my "be prepared" mentality I also have a flat fix kit, the tools needed to replace a tire, and roadside service plan. OK OK probably overkill but as I said I am the cautious type.  (WH)
..Mike
Mike & Pat Astley,
Michelle Dungan
Gandalf42, you answered two questions I'd wondered about: A spare tire mounted in front of the grill will obstruct airflow and, that it will help counterbalance the vehicle rearend weight and make it ride better.  I would imagine going without a tire cover on it would help airflow some, though.  As for spares on roofs, I can't imagine hauling one up or down the rear ladder!
For better weight distribution than the rear mount for the spare several feet above where a bumper would be if they sensibly had one, it's too bad there isn't room to mount one underneath, as in some pickups, and with a similar lift mechanism.  But, that'd probably be a different rig with a basement.  Compromises, compromises....
« Last Edit: February 03, 2017, 02:30:54 am by Michelle Dungan »
