Beware the Emergency Window
  • 12091 Views
Dave R
  • 24
  • PurchDate: Delivered 12/16/16
  • ExtColor: Desert Sand Full Body - modified
« on: January 27, 2017, 07:59:18 pm »
I sure messed up today.  I had read on the forum that if the emergency window was opened too far it would fall out.  So I set up a ladder on the outside and carefully opened the window (about 18") until the left corner slipped down a little.  I gently pushed it back up and carefully tried to close it and the long narrow window above it shattered.  I am very mechanically inclined and have never seen anything so fragile! Hopefully since it is a 3 glass unit I can replace only the fixed upper piece.
I know it is an emergency widow but it would sure be nice to have one that could open and close easily like in my other RV's without breaking.  I advise to never open more than 12 - 14".
I am really upset since it has been too cold to even take my first trip.
Bummed out in Montana.  javascript:void(0);
Dave R
  • 24
Re: Beware the Emergency Window
« Reply #1 on: January 27, 2017, 08:30:14 pm »
One additional note the upper glass window shattered and shards went everywhere - it did not act like safety glass at all.
Has anyone else experienced broken widows and had shards of glass everywhere?
Dave
swiftboot
  • 119
  • PurchDate: 10-31-16
  • ModelYear: 2351----2015
« Reply #2 on: January 27, 2017, 08:31:28 pm »
I am sorry for your damage but hopefully your experience will prevent it happening to others.  Did you experiment with opening and closing it the few inches such as the crank out window?  If so did it close and seal as before opening?  I think I could live with it being opened just a few inches but with your situation, I would be hesitant to open it at all.
Larry
David Rotelle
« Reply #3 on: January 27, 2017, 09:46:26 pm »
Dave,
We never had an experience like that with a Motorhome but we did have and unusual experience with our new John Deere Gator recently. Our Gator has a full glass cab with a large windshield, the windshield is hinged for ventilation. I pushed the window closed from the outside and it exploded, it sounded like a shot gun blast with a bright flash, I found glass as far as ten feet away.
We use the gator to travel from one farm to another at speeds in excess of 30 mph. I was thankful it did not happen while traveling down the road but disappointed something like that would happen with a windshield.
Our John Deere dealer said windshields are not covered under warranty, I can understand that but I'm not sure why they would have glass in the windshield that would do that.
We were told that it was most likely a flaw in the glass referred to as an air pocket, perhaps that's what was wrong with your window?
Sorry to hear about your situation that's unfortunate. I thought about opening our Emergency window but because of your post have reconsidered, thank you for sharing what happened.
I'm Dave R as well....
« Reply #4 on: January 28, 2017, 08:53:43 am »
Last week I posted this about opening the emergency window.
The stick Bob gave us was 13" long, no problem putting in or out or window falling out.
But don't push it too high.
So it's OK to open and use for more ventilation but be aware of the opening limit of 13".
« Reply #5 on: January 28, 2017, 01:47:01 pm »
Dave, I've been told that glass is more likely to shatter when it is cold. I had to replace a sliding glass door on a rental house once and the tech said it was due to a gentle impact on very cold glass. The tenant was running a day care out of the house so I wasn't convinced it didn't get clocked hard with something but the repair guy said it happens a lot in the winter. It's possible you hit one of the Bermuda Triangle trifectas and combined flawed glass with cold weather and an unusual impact or torque and away it went. I haven't heard of anyone else's emergency window shattering on them.
« Reply #6 on: January 29, 2017, 08:50:03 pm »
Dave
That's called tempered glass.   It breaks into tons of little pieces rather than large sharp pieces.   Safety glass is only used in windshields, not side or rear glass.  That's true of all vehicles sold in the U. S.
