Lost Power To Driver Side Slide
  • 1 Replies
  • 8577 Views
JoeyD
  • 77
  • PurchDate: 1/16/2013
  • ExtColor: Black/Grey
« on: December 08, 2016, 09:00:51 pm »
After a 2 day overnighter in St Pete Florida, I started packing up to move out. While pulling in the driver side slide I heard a "pop" just as the slide reached the end. I tried to push the slide back out to investigate but no power at all. The other 2 slides were fine. I checked the breakers and they are just fine. Has anyone experienced this before. Any chance I broke something while pulling the slide in?
Thanks,
Joe
HenryJ
  • All ready for the road
  • ModelYear: 2016 / 2910T
  • IntColor: Hickory (light)
  • ExtColor: graystone
Re: Lost Power To Driver Side Slide
« Reply #1 on: December 12, 2016, 07:53:33 pm »
If the slide is out so you cannot move there is a plug in the bottom edge of the slides and you can remove and there is a way to crank it in for travel... Call the powers that be and have them give you a run through.  Good luck. Patricia and Jim in Tampa
Patricia
