Cleaning the rubbery seam material
  • 18 Replies
  • 28407 Views
Gail Staton
« on: July 15, 2016, 09:29:07 am »
The white vinyl or rubbery seam material above the windshield and passenger/driver door and along the sides where the seams are located is quite dirty looking on our 2100.  Has anyone found a cleaning product that works for this material?   Normal car wash and black streak cleaner are not getting it clean.  I have tried a Magic Eraser being careful not to touch the painted surfaces but it's not removing the dark grey or blackish marks either.
Thanks for any suggestions.
Gail
Re: Cleaning the rubbery seam material
« Reply #1 on: July 15, 2016, 10:44:51 am »
Purple spray cleaner that is found in automobile section of Walmart.
Gail Staton
« Reply #2 on: July 15, 2016, 01:34:08 pm »
Thanks Tom.   I appreciate your reply.
Gail
  • 5717
« Reply #3 on: July 15, 2016, 05:43:14 pm »
If that doesn't work, try scratch remover also sold at Walmart, in their automotive paint care section.
Gail Staton
« Reply #4 on: July 15, 2016, 07:30:37 pm »
Thank you too, Ron.   Looks like we are going to Walmart.
  • 5717
« Reply #5 on: July 16, 2016, 08:24:52 am »
Sold at Walmart for under $5.  I think I've seen smaller bottles on the shelves priced less, but it's been a while since I was a-lookin.
« Last Edit: July 16, 2016, 08:33:18 am by ron.dittmer »
Gail Staton
« Reply #6 on: July 16, 2016, 05:52:08 pm »
Hal had the Turtle Wax Scratch Remover in the garage.  We tried it before heading to Walmart.   It did clean it somewhat but would take forever to clean all that seaming inch by inch and lots of elbow grease.
Tom,
We did see a spray bottle of Purple Power Industrial Strength Cleaner & Degreaser.  Was that the product you recommended?
Gail
  • 5717
« Reply #7 on: July 17, 2016, 02:26:04 am »
Hi Gail,
How I use the scratch remover on such surfaces makes a huge difference in the amount of effort required and desired results.  I have found it best to use an old cotton tube-sock with the fluffy inside turned out.  I also cut off the elastic part that goes around the leg.  If I use an applicator sponge, a paper towel, a t-shirt rag, or anything else on such surfaces, I work much harder and get less desired results.  I don't know what it is about old tube-socks, but they work best for me doing such detail work.
Admittedly I have a full body paint job on our PC so there is no raw plastic, therefore I am not experienced with unpainted PC materials.  My experience is on other vehicles where once shiny smooth unpainted plastic has faded, stained, and lost it's shine.  Plastic headlight lenses are most popular a project for it, but requires time and effort.  Tail lights and and other smooth plastic is much easier.  Do NOT use on textured plastic or black unpainted bumper covers.
« Last Edit: July 17, 2016, 07:46:52 am by ron.dittmer »
« Reply #8 on: July 17, 2016, 06:50:40 am »
Tom,
Gail
Yep that is it.
  • 5717
« Reply #9 on: July 17, 2016, 07:44:49 am »
Tom,
Gail
Yep that is it.
Hopefully Tom's recommendation goes easier for you.
Gail Staton
« Reply #10 on: July 17, 2016, 08:26:04 am »
We do have a supply of old tube socks with the terry-like inside.  Years ago we saw a tip for cleaning off your hoses and electric cord when breaking up camp.   Turn the sock inside out and wear like a glove on one hand,  wipe the cords and hoses with that hand as you wind them up for storage. Hal's been doing that since our first rv.  Works better than a rag.
It is only the white rubbery seam material that is dingy looking not the body of the PC.   Since yours is full body paint, that material  is painted to match the rest of the body.   On our half body,  the seam material is white and not painted.    We will give the sock a try.
Thanks so much for your suggestion.
Gail
Gail Staton
« Reply #11 on: July 17, 2016, 08:40:12 am »
Tom,
We will get some Purple Power and hope it does the trick.
Thanks again.
Gail
Gail Staton
« Reply #12 on: July 18, 2016, 07:52:10 am »
Thanks for the suggestion Tom but no luck with using Purple Power.
 I am going to try one more option, a moss, algae, mold remover.  The hardest area to reach is the seaming above the windshield and of course that is the dirtiest looking.   Our PC was two years old when we purchased it a year ago so we don't know what caused this condition.   Whatever it is, it sure stained that seaming material.  The rest of the coach is brand new looking.
Thanks for taking your time to help.
Gail
« Reply #13 on: July 18, 2016, 08:58:55 am »
Boy that must be one tough stain. I would try the purple stuff and let it sit for a few mintues before wiping it off. If that doesn't work, I would call Kermit.
Gail Staton
« Reply #14 on: July 18, 2016, 09:57:33 am »
I agree Tom.   It is a tough staining to remove.   We did let the Purple Power sit but no budge in the staining removal.  The scratch remover did remove some, probably because of having abrasive material in the ingredients.   Hal's small rotary tool has a buffing pad attachment we thought about trying.     Otherwise we would be applying it inch by inch, rubbing very hard and wearing out our old fingers.  Even doing that it doesn't remove much.
I wish that seam material had been painted.  When we get down to the lower painted area it is perfectly clean.   The material reminds me of gasket material on refrigerator doors.
I thought about calling PC but wanted to exhaust all my ideas first but I guess that's backward thinking.  They may know exactly what to use or say nothing works, live with it.
Gail
