Pros and Cons of Insulated Glass and Rear Ladder/roof rack
  • 11 Replies
  • 19294 Views
JOHN
  • 50
  • PurchDate: pickup 10/2016
  • ModelYear: 2016 - 2351 Ford
  • IntColor: Nightscape
  • ExtColor: Standard Paint
« on: June 01, 2016, 07:55:36 pm »
I am close to ordering a 2351 and would like your comments on whether you would add the Insulated Glass and/or remove the ladder/roof rack.
I have had a number of SUV's with roof racks and never utilized.
I am adding Solar Panel, though they seem to be installed in front, gas line w/ quick disconnect, surge protector w/regulator, and upgrade 15000 BTU A/C.
Anyone ever add the Central Vacuum?
Thank you,
Re: Pros and Cons of Insulated Glass and Rear Ladder/roof rack
« Reply #1 on: June 01, 2016, 09:24:01 pm »
IMO dual pain windows are worth the money just for the quite they bring to the coach.  You do not have to worry about weight (over) in a 2350 as long as you go with the E-450.   no opinion on the central vac system, seems like a little over kill.  I like a ladder just so I can have access to the roof if needed.
« Last Edit: June 02, 2016, 02:37:31 pm by ragoodsp »
Dynadave
  • 85
  • PurchDate: 10/2018
  • IntColor: Tan
  • ExtColor: White/brown
« Reply #2 on: June 01, 2016, 09:24:38 pm »
I am a fan of the insulated glass, big improvement over single pane, the coach is quieter as well as better insulated. I would keep the ladder, if a problem with a leak, vent, antenna etc. occurs while traveling it is nice to be able to get up on the roof. I found a hand vacumn more handy than the central  vac I had in one of my class A's.
2018 Phoenix 2552
JOHN
  • 50
« Reply #3 on: June 01, 2016, 10:18:45 pm »
Thanks, I will go with the insulated glass and keep the ladder and roof rack. Central vac does seem like an overkill for RV.
« Reply #4 on: June 02, 2016, 06:55:41 am »
I kept the ladder but deleted the roof rack. I can get onto the roof and don't have the rack in the way. Also easier to wash the roof.
For vac, my wife got a Dyson cordless that I mounted in the wardrobe. I had to run an extension cord to it but it works. If I had know before hand I would of had the factory  install an electric plan in the wardrobe. I will say it works really well and I can take it to the toad and vac it. She liked it so much she got one for the house.
« Reply #5 on: June 02, 2016, 02:39:51 pm »
I would vote a big "yes" on Tom's approach....scrap the roof rack and keep the ladder.  It is a pain clearing snow, etc with the rack in place.  I honestly did not think of separating the two....
HenryJ
  • All ready for the road
  • ModelYear: 2016 / 2910T
  • IntColor: Hickory (light)
  • ExtColor: graystone
« Reply #6 on: June 02, 2016, 03:12:13 pm »
we have just given up the central vacuum. It was a pain. The bag area is out of the main cabin so changing it is an outside job. The tools were a lot of trouble so they remained away. We use a Bissell that works as a hand vac or fits in beater brush assembly. Handle folds down for stowing away. is rechargeable and picks up dog hair. No bags except the old one on the handle.
Patricia
Bob Mahon
  • 547
  • PurchDate: 6/2011
  • IntColor: Tan/Gray/Cherry
  • ExtColor: Lower Slate Gray
« Reply #7 on: June 02, 2016, 11:19:40 pm »
The previous 3 comments are spot-on.
Having bought 2 of our 3 PC rigs from the factory, lose the roof rack (which is a pita to climb over).
The central Vac is not necessary and also a pita.
The ladder can also be deleted if you buy a Telesteps type ladder, which can be positioned anywhere on the rear or sides and will fit in the storage bay.
We didn't need the insulated windows in our summer travels but that's a matter of preference.
The higher rated air conditioner/heat pump is a good option.
PC is a wonderful company and their after sale support is without peer (I've had units made by others). They really do care about PC owners.
« Last Edit: June 02, 2016, 11:22:32 pm by Bob Mahon »
SweetWaterSurprise
  • 25
  • ModelYear: 2009
« Reply #8 on: June 03, 2016, 11:28:21 am »
Have both the ladder/roof rack and insulated glass, great additions.  The vac I think is unnecessary.
Waterdog
  • 15
  • Cross village mich on the BMW GS
« Reply #9 on: June 05, 2016, 11:15:09 am »
I'am currently looking it used Cruisers and how could you tell if it had the insulated glass . The insulated glass seems like a good option for cool weather usage .
Thank you
« Reply #10 on: June 06, 2016, 06:53:55 am »
If it is the type that cranks open instead of sliding, then you check from the outside. Crank open a window then go around outside and look at it from the edge. The two panes of glass with a spacer between is visible. The outer pane is large than the inner pane. The inner pane and spacer fit inside the window frame when closed. The outer frame aligns with the fixed glass on the rest of the window.
  • 5718
« Reply #11 on: June 09, 2016, 02:12:06 am »
I ordered our 2007-2350 new (9 years ago) with insulated glass and also the roof rack and ladder, but I requested the ladder & rack be placed inside the rig in pieces.  Nine years later, both remain stored in our brick-&-mortar house basement leaving me to wonder if I should put them up on Ebay or Craigslist along with a pile of other retired PC items collected over the past 9 years.  If you are unsure what to do, I suggest you consider what I had done.  You can always install one or both later.  But taking either off will leave unsightly plugged holes.
About insulated glass, I agree with the others.  It is well work the extra cost for the reasons shared.  We are very happy we with them.
Sorry but I feel a central vac an unnecessary complexity, especially in the smaller PCs.
« Last Edit: June 09, 2016, 07:49:21 am by ron.dittmer »
