power to TV and DVD Player
  • 3 Replies
  • 9562 Views
lad07
  • 10
  • PurchDate: 1/2016
« on: April 25, 2016, 10:10:50 am »
While on a recent trip in my 2100 I tried to use micro and toaster at same time while plugged into campground 30 amp.   :-[   After getting power working again the TV and DVR player doesn't work. I plugged them into another outlet and they work. Anyone have suggestions what to do?
Gail Staton
Re: power to TV and DVD Player
« Reply #1 on: April 25, 2016, 10:28:29 am »
I'm sure someone here with a lot more knowledge than me will chime in but my guess is you need to reset a breaker or the GFi outlet.  Too much draw on the circuit used.  I'm probably using the wrong terminology but you probably know what I mean.
« Reply #2 on: April 26, 2016, 12:27:02 am »
Gail has it right.  Check the 110V circuit breakers and the GFI outlet in the bathroom.   I believe there is only one GFI outlet in a 2007 2100 and it is in the bathroom.  I would flip every 110V breaker off and on again to make sure they are in good order.  I would also hit the red and black buttons on the GFI outlet to test it.  A "tripped" GFI always confuses me which is on and which is off.  I use the trial and error method.
Let us know what you find.
« Last Edit: April 26, 2016, 12:46:27 am by ron.dittmer »
lad07
  • 10
  • PurchDate: 1/2016
« Reply #3 on: April 28, 2016, 10:11:10 am »
Thank you, for the replies. I did try pressing the GFI a few times the day I goofed and used the micro and toaster at the same time. Also, flipped the 110V breakers on and off. It didn't help. I'm going camping today and will try it again.
Thanks you,
lad07
