Apollo Oven Power Loss
  • 0 Replies
  • 16446 Views
« on: April 18, 2016, 05:38:47 pm »
While using our Apollo microwave/convection oven this winter we suddenly lost power to it.  Everything else in the PC was fine.  After removing it from over the stovetop (thanks to Bobby's instruction), and removing the metal cabinet we noticed a black spot on the white mesh cloth (see pic below).  We pulled the sleeve back to expose a High Temperature Fuse.  We checked wire continuity on each side of the fuse and it was fine.  We then jumpered the fuse and this restored power.  We now knew we had a dead fuse that needed to be replaced.
We called the Apollo Service Center and their technician confirmed that the temperature fuse was at fault.   He ordered a new High Temperature Fuse ($30.00 very over priced) for us.  We replaced it and all is fine.
The part that we replaced was a microtemp G5A00 rated at 120 degrees Celsius. The new fuse that was sent to us was a microtemp G5A01 rated at 152 degrees Celsius.
Additional research indicated that the normal life span for this type of device is between 5-6 years.  We will order a spare (less than $2.00) before our next trip.
The Apollo technician was very helpful.  He said if the oven is in a "dead condition", there are three safety components that need to be checked.
    1.  A 20 AMP, 120 volt fuse located on the top right rear corner (you can see this in our pic).
    2.  The magnetron thermostat which is mounted to the side of the magnetron tube.
    3.  The High Temperature Fuse (this was our failure).
