Roof Rack Ladder
  • 8 Replies
  • 18038 Views
gl1500
  • PurchDate: May. 2014
  • ModelYear: 2551/2014
  • ExtColor: Cafe'
Roof Rack Ladder
« on: August 24, 2010, 05:35:39 pm »
The roof rack is handy when needed to check anything on the roof. But, the majority of time it is an obstruction to get in the rear compartment.  My solution: Pull the pins, move the bottom free of the bottom brackets and then reinstall the pins.  Place the the lower portion of the ladder in the up or storage position.  I then use double sided velcro straps and wrap the upper and lower ladder sections vertical tubes(both sides).  Make them tight so they can not rattle and chafe each other.  Now I have free access to the rear compartment, but still have my ladder available if needed.  The double sided velcro comes in a roll and also becomes handy for securing a myriad of things.
   Idaho
Bob Mahon
  • 547
  • PurchDate: 6/2011
  • IntColor: Tan/Gray/Cherry
  • ExtColor: Lower Slate Gray
Re: Roof Rack Ladder
« Reply #1 on: August 25, 2010, 07:50:20 am »
I do exactly the same thing as I go into the bay a lot more than I ever go onto the roof.
I had to do that in Wyoming to fix the antenna rattle that was driving me nuts.
It was extremely windy and I was almost blown off the roof.
I'm not big on using ladders.
  • 5744
« Reply #2 on: August 25, 2010, 11:18:37 am »
When special ordering mine in 2007, I made a bold decision (bold to me anyway) to request the factory "Not" mount the roof rack or ladder, but instead place them inside the RV.  I disassembled and stored them in my basement.  So far I have not regretted that decision.  The only time I get up top is to wash the roof of which I use my home ladder for that.
I do admit I was initially inspired to leave them off to improve my walk-around clearence of the RV when parked inside my garage.  If I had the ladder attached, I'd have to open the garage door to get around the rig.  But I quickly appreciated the cleaner appearence, ease of washing, and less caulked-over holes in sensitive places.....ie the roof.
The only concern I have is when camping, if I tangle a branch in the a/c or other vent.  I don't have any way of getting up there to untangle it.  But given the PC is lower than most motor homes, the scenario is unlikely.  So far so good.
« Reply #3 on: August 25, 2010, 02:40:22 pm »
When I ordered my PC, I had them keep the rack, but to put the ladder on. The first morning after pickup, at 5:00 am, I found out how hard it is to see the little pins in the pins holding the ladder down can be in the dark. I found that I had two 3" pins with 2" rings on them that belonged to a trailers ball hitch. The pins fit perfectly in the holes for the orginal pins and don't need anything to hold them in. Using the orginal wire I attached the rings/pins to the ladder. Now I can just put the pin, let it hang from the ladder, raise the ladder and go for the truck. Works for me. I don't miss tripping over the rack when I need to get up on the roof. I hope to use the roof as a platform for taking pictures while we are in Yellowstone and on the Beartooth Highway, so the ladder will be very handy.
  • 5744
« Reply #4 on: August 25, 2010, 03:43:41 pm »
Just be careful up there.  Not only a concern of falling off, but also damaging the roof.
I weigh 180 pounds and sense the roof a bit soft for walking on.  I try to limiting myself to crawling on all fours and even then limitedly.  On rare occasion I'll stand barefoot on the roof to work the garden hose around the a/c or antenna when washing it.  It's not a comfortable feeling.
« Reply #5 on: August 25, 2010, 05:50:53 pm »
Ron, the way they built my roof, I bet we could have the entire girls softball team up there at one time. The roof is alot stronger than my old Winnie was. My only concern is how slick it gets when it is wet. I have my wife watch as I wash the roof, just in case I slip. She can count the number of times I bounce.  roflol
mciai2000
  • 365
  • PurchDate: 09/2011
  • IntColor: grey
« Reply #6 on: August 26, 2010, 09:24:31 pm »
Tom: Now that is funny!.
I send my 11 year old son up on the top when I need to wash or check on the roof. (cheer)
Happy trails....
DJM
kevin
  • 156
  • PurchDate: 9/2010
« Reply #7 on: August 26, 2010, 09:33:17 pm »
Wash the Roof?  Now, that's funny.javascript:void(0);
kevin
NLK
  • 82
  • PurchDate: August 2010
  • IntColor: Cherry / Gray
  • ExtColor: Gray full paint
« Reply #8 on: September 05, 2010, 10:30:13 pm »
I also was annoyed with the roof rack ladder being in the way of the rear storage compartment.  This is what I did on my 2007 and 2008 2551 PC.  I removed the bottom section of the ladder and hinge by simply removing the screws.  I unscrewed and removed the pin brackets that are attached to the fiberglass body on the bottom.  I bought 1" caps made from plastic or rubber, black or white, and slipped the cap over the end of the ladder tubing. This made for a more finished appearance and eliminated the sharp edge that you could get injured on.  The caps are actually used for the bottom of chair legs to protect  flooring.  I put 2 small red adhesive backed reflectors over the bracket holes in the fiberglass.  I also put 2 more on the rear driver's side to make it look even across the rear.  If later on you decide you want the ladder installed again the reflectors can be removed with a hair blower and careful coxing.  Any sticky residual can be easily and safely removed with WD40.  I have gained a great deal of knowledge from everyone and can only hope that this will be helpful to someone and that I finally have made a useful contribution to this forum.
