Register
Login
1 Hour
1 Day
1 Week
1 Month
Forever
Hello
Guest
Menu
Home
Help
Search
Login
Register
go
Cruisers Forum
Main Forum
General Discussion
Lighted grab bar by the door
« previous
next »
Pages: [
1
Go Down
jfcaramagno
178
NewUsed: Used
PurchDate: Feb. 16, 2015
Model: 2552
ModelYear: 2014
IntColor: Cherry
ExtColor: Sunlit
on:
September 02, 2015, 06:51:54 pm »
Our lighted grab bar isn't. Lighted, that is. The bulb is fine and a new bulb also doesn't light. My VOM says there is no voltage with the porch light on (I assume the bar lights with the porch light). Any ideas where I should look?
Thanks.
John and Carol
1165
PurchDate: 10/17/11
Model: 2551
ModelYear: 2012
IntColor: Cherry
ExtColor: Classic Umber
Re: Lighted grab bar by the door
Reply #1 on:
September 02, 2015, 08:22:49 pm »
In our 2012 2551 the grab bar light always comes on with the porch light.
I replaced our porch light this year and there was only one pair of wires connected to it. It was wired with one pair of wires from the switch to the grab bar and then from the grab bar to the porch light. The factory may have changed by running two pairs of wire one to the grab bar and then another to the porch light and then both terminating at the switch. You could call the factory to see if there are two separate wires run or just one.
I would remove the switch inside the PC and make sure there are no wiring or switch problems.
If the porch light comes on and the switch looks good I would check the socket in the grab bar for a problem. If the porch light does not come on then I would check for a blown fuse.
Last Edit: September 02, 2015, 09:22:12 pm by Barry-Sue
Current 2012 2551 w/Slide
jfcaramagno
178
NewUsed: Used
Model: 2552
ModelYear: 2014
IntColor: Cherry
ExtColor: Sunlit
Reply #2 on:
September 05, 2015, 11:57:15 pm »
I took the switch apart and found only one pair of wires attached. That means the grab bar must be powered from the same wires that power the patio light. I tried to take the patio light apart but it seemed to be glued to the wall and I didn't want to break it trying too hard. So I took the grab bar apart again and looked at the pair of wires going to the light bulb. There were two butt connectors wedged into a hole in the wall, so with few options I pushed one of the connectors back into the hole and the light came on.
I don't usually believe in magic, but it works now. Go figure.
John and Carol
KB9OMH
168
PurchDate: 3/26/13
Model: 3100
ModelYear: 2013
IntColor: Maple
ExtColor: Sterling
Reply #3 on:
September 06, 2015, 08:43:39 am »
Sound like one off the butt connectors has a loose connection, meaning the butt connector didn't get crimped good enough, which also means you will most likely have the same problem again.
Jim
SweetWaterSurprise
25
NewUsed: Used
ModelYear: 2009
Reply #4 on:
September 08, 2015, 09:07:56 am »
I don't doubt something has come loose if the patio light comes on. I changed my bulbs to LED for both.
jfcaramagno
178
NewUsed: Used
Model: 2552
ModelYear: 2014
IntColor: Cherry
ExtColor: Sunlit
Reply #5 on:
September 10, 2015, 06:52:25 pm »
What LED did you use for the grab bar?
John and Carol
SweetWaterSurprise
25
NewUsed: Used
ModelYear: 2009
Reply #6 on:
September 11, 2015, 09:46:09 am »
Quote from: jfcaramagno on September 10, 2015, 06:52:25 pm
It was a 194 type bulb mounted at the top section of the handle.
jfcaramagno
178
NewUsed: Used
Model: 2552
ModelYear: 2014
IntColor: Cherry
ExtColor: Sunlit
Reply #7 on:
September 11, 2015, 07:37:18 pm »
Thanks.
John and Carol
Pages: [
1
Go Up
« previous
next »
