Ron's Tips For Class C /B+ Shoppers
  • 8 Replies
  • 43085 Views
« on: September 07, 2014, 11:56:35 pm »
I post this on occasion as a reply to people shopping for a class C on other forums and thought it would be of interest to people browsing this PC forum.  It morph'd into more of an article rather than a reply.  It is an objective opinion (or so I tried), not a sales pitch for a PC, though I use my own 2007 PC-2350 as a given "positive" example.
New, used, or well used, when shopping for a conventional class B+ or C, the most important consideration is how it is constructed.  This post outlines construction methods which are most affordable and methods that cost more, but are built to hold up much better to the elements and also the punishment of the road.
Some motor home manufactures offer different levels of quality through their various model lines. Instead of providing a list of brands to consider, it is best to identify what "Better" is.
When shopping for a motor home, don't get distracted with "Eye Candy" and "Square Footage". You want to pay close attention to how the house is constructed.  Water infiltration is the number one killer of motor homes, rotting them away long before anything is worn out. Once water gets inside, it is like termites.  By the time you realize there is a problem, a lot of damage has already occurred. Also consider that mold & mildew can grow inside the walls which then you have a health hazard. My advise focuses on identifying a reliably well sealed motor home.
#1 BEST (Very Expensive, Can Be 1.5 times the cost of Second Best)
NO structural seam work. The brand Coach House is a fine example. It is seamless, made from a mold. The only places where water can leak is cutouts for windows, entry door, roof-top vents & a/c unit, storage compartments & maintenance access, all of which are in areas of very low stress. Because they have a seamless shell, these motor homes are not common and have a limited selection of sizes and floor plans.
#2 SECOND BEST
Common, Affordable, & comes in Many Sizes so this is my main focus
I own an example of this type.   My Rig Here manufactured by Phoenix USA.
Made in sections, but assembled in a way that greatly reduces the threat of water damage. Here are the good things you want to look for.
a) Structural Seams Away From Corners
When a motor home is driven, the house bounces, resonates, shakes, and leans countless times, representing a endless series of earthquakes. Corner seams see greater stresses than seams located elsewhere. Corner seams are more easily split, especially when the caulk gets brittle with age & exposure to the sun. One extremely bad bump in the road can instantly breach a corner seam. Seams hold up much better when they are brought in from the corners in lesser stressed areas.
b) A Seamless Over-The-Van Front Cap
A huge bed above the van’s roof is the most vulnerable area of a motor home. No matter how well they are made, that long frontal over-hang resonates when the RV is driven making it common for seams to split there, most troublesome with age & exposure to the elements.  HERE is an example, one of many water-damage threads I have read.  Scroll down in that thread to see pictures of the real damage.
The small front aerodynamic cap of a B+ design HERE eliminates the overhang which eliminates most of the resonation, along with the most vulnerable seam work.
There are a few conventional “C” Designs (big over-van bed) where that area is seamless. If you absolutely must have that huge bed, then look for a seamless bucket-like design.  The Itasca Navion is a fine example.  If your requirements are to have a large class-C with a massive over-van bed, the best example I seen was this Fleetwood Tioga model offered around 2008-2009.  It is unfortunate all class-Cs don't practice seamless cab-over area construction for it would greatly improve the class-C industry.
Increasing in popularity by many manufactures is a shallow bucket design with fewer seams located in less-stressed areas.  The Nexus Triumph is one such example.  This shallow bucket design is a reasonable compromise.
If you plan to accommodate more than 2 people, having that large extra cab-over bed will be extremely useful.
c) A Crowned Roof
Rain and snow melt runs off a crowned roof. A flat roof will sag over time, then water puddles around heavy roof-top items like the a/c unit. Water eventually finds it's way inside after gaskets & caulk have degraded from age, sun, and change in seasons.
d) Rolled-Over-The-Edge seamless Fiberglass Roof Sheathing
A single sheet of fiberglass as shown HERE that rolls over the right & left sides of the roof, down to the wall. The overlapping of fiberglass to the wall provides a good water seal and the fiberglass sheathing holds up better than roofs made of sheet rubber or thin plastic called TPO, which require more attention to keep your RV well protected.
e) A Five Sided Rear Wall Cap
A five sided back wall moves the seams around to the sides to areas of much less stress as seen HERE.  The rear wall resembles a shallow rectangular cooking pan standing on it's side.  Like the example, some rear wall sections are constructed with an integrated spare tire compartment and rear storage compartment.  Not only are they convenience features, but that rear wall/cap offers a solid double-wall for exceptional strength which is more resistant to flexing the adjoining seam work.  It helps in keeping the house together.
Don't be fooled.  Some manufactures add rear wall sectional styling which gives the appearance of a 5-sided pan design.  Though not as desirable, they are still an improvement because all the holes for lighting and such are not in the structural wall where water could otherwise get inside the house.  You can easily tell by noting the sections & seams between them and the flat back wall that remains exposed.  CLICK HERE to see an example.
f) Walls Are Either Resting On The Floor Or Fastened Against It
Common sense would say the walls should rest on the floor, but some manufactures actually fasten the walls into the side of the floor framing as ILLUSTRATED HERE.  This means the weight of the roof and walls (and everything hanging on them) rests on the fasteners.  How well will that method hold up when being driven for so many thousands of miles?  Checking for this is very difficult.  It takes a trained eye for sure.  CLICK HERE for an example of it done right with the walls resting on the floor.
Bigger Will Be Weaker
The size & floor plan you select MUST FIRST meet your needs before this consideration.
The bigger the house, the weaker the structure will be.  Consider two cardboard boxes made from the exact same corrugated material.  The smaller box would naturally be stronger.  It will be more resistant to bending, twisting, and other types of flexing.  So if you are on the fence between models, the smaller one will be your stronger choice.
Potentially Troublesome Construction
Entry level motor homes are made with seams in corners and finished off with trim, including the massive cab-over bed.  Their roof is flat and finished with rubber or TPO. They are most affordable, and come in all sizes. HERE is one such example.  If considering this construction type, keep in-mind they require more regular care with bi-annual inspections. Plan to use a caulking gun now and then. When buying a used one, consider that you really don't know how well the previous owner maintained it. Buying new or used, that construction method will be counting on you to be a good non-neglectful owner.
There are also the rare exception like the recently defunct LAZY DAZE which has seam work in the corners, but the substructure and sealing method is of the highest quality that it holds up like a seamless body.  It is also worth noting that the company never utilized slide-outs.  It's excellent sectional construction methods are not commonly found in other brands. I am no expert on this, but I'd give it a #1.5 Almost Like Best
A Caution Concerning Slide-Outs
Slide-outs are most popular.  Everybody loves the extra floor space they provide.  There are so few motor homes made without at least one slide-out.  Unfortunately slide-outs can introduce risk of water damage to the main floor around them.  Good seals work when the rig is young, but can loose their ability to seal properly as they age.  When looking at used rigs with slide-outs, closely examine the main floor around each one.  If you can lift the carpet adjacent to the slide-out and see the wood floor is a gray color, that is a sign that water gets inside.  Also, completely open the slide-out and step on the main floor adjacent to the slide-out.  If it feels soft, the plywood or chip board material underneath likely requires replacing.
Not All Slide-Outs Are The Same
Some slide-outs have a single motor system with a backup method of drawing in the slide-out in-case of a failure.  They include a hex bolt that you attach a crank onto and crank it in manually.  Since slide-outs have gotten bigger and heavier, two motors have become neccessary which requires electronics with software to keep them synchronized.  The added complexity of the over-all system dramatically increases the frequency of issues.  The worst part is, you can't crank in these like you can with most single-motor slide-out systems.  If you see a slide-out with THIS then it has the two-motor complex system.  If you see angled bars along the sides like THIS then you have identified one of the most reliable slide-out systems which includes a manual crank-in back-up.  Unfortunately, RV manufactures don't like to mix systems.  If one of their models require a two-motor system, then whether big or small, every slide-out in every model gets the same system.
Slide-Outs Containing Appliances, Sinks, And More
A slide-out with a fridge or stove, and a sink, has to extend and contract the appropriate connections.  How many in's and out's does it take until something goes wrong?  Here is a list of systems that require special consideration, if placed inside a slide-out.
110V Electrical Umbilical Cord or Cords
12V Electrical Umbilical Cord or Cords
Hot Water Umbilical Cord
Cold Water Umbilical Cord
Waste Water Umbilical Cord
Propane Umbilical Cord
Furnace Heat Duct Umbilical Cord
Coax Umbilical Cord
Speaker(s) Umbilical Cord
Location Of Slide-Outs
It is very common for a slide-out to be located directly behind the driver seat.  If you are a tall person, this can greatly limit the positioning of the driver seat when the slide-out is brought in for driving.  So be mindful of this limitation.  The condition SEEN HERE is easy to spot from the outside.
A few manufactures have angled transition walls between the van and the house that naturally sets the slide-out farther rearward as SEEN HERE.
Concern Over Bad Plumbing Practices
Once in a while, a manufacture of motorhomes will simply Build Bad.
1) CLICK HERE for a picture of the whole house water filter, and CLICK HERE for the water pump, both placed in the same compartment with all the electronics.  If anything comes loose and water sprays around inside this compartment, your motorhome is electrcially destroyed.
2) CLICK HERE and CLICK HERE to see hot and cold water plumbing lines being routed underneath the motorhome, completely vulnerable to freezing.  Summer camping at high altitude and in Canada will often see temperatures below freezing, with spring and fall being much more threatening.  Think about the ruptured plumbing you will forever deal with over this engineering debacle.
About The Chassis
The most popular is the Ford E450 with the 7.3L-V8 engine, a notable improvement in power and fuel efficiency over the 6.8L-V10 it replaced in 2020. The Ford Transit diesel & gas turbo along with the Mercedes Sprinter diesel are popular alternatives.  The GM 4500 chassis is not popular but is a very good choice for the right application. Any of the chassis mentioned made since 1998 are real good, new or used. If you plan to tow a car or trailer, be aware that the Transit and Sprinter will be least powered. People who tow with them, tow lighter and cruise slower.  Do your research if you have something specific in-mind to tow.
If considering a recent “small” class B+ or C motor home, here is a comparison between the two current primary chassis contenders, the Sprinter with the V6 diesel engine and the Ford E450 with the 7.3L-V8 gasoline engine.
Advantages Of The Mercedes Sprinter With Diesel Engine
- Offers a 30% improvement in fuel economy over the Ford-V8, when both are loaded and driven identically.
- More ergonomic driver compartment with more leg room.
- Comfort continues with a car-like feel & quiet ride.
- A grander view out the windshield
- Made by Mercedes which people are attracted to.
Advantages Of The Ford E350 & E450 with gasoline V8 engine
- Given identical motor homes both brand and model, the Ford is around $24,000 MSRP cheaper
- The Ford V8 engine has nearly a 50% increase in horse power and 25% increase in torque.
- The Ford E450 chassis handles roughly 4000 pounds more weight.
- The E450 is able to tow a heavier load.
- The E450 rear axle is significantly wider which translates to better stability.
- In most places traveled, gasoline costs less than diesel fuel
- The Sprinter diesel has limited mechanical service shops around North America
- The Sprinter diesel is typically outfitted with a propane generator.  Propane is a critical fuel for RV operations, and generally needs to be rationed when dry camping.
- The V6 Sprinter (and Transit) diesel engine is not allowed to idle for extended periods. This limitation is detrimental when you need a/c but there are generator restrictions, you are low on propane, or you have a mechanical failure with the generator or roof a/c. The Ford gas engine offers a great backup system. The V8 can safely idle for hours on end, heating, cooling, and battery charging, all valuable if you have a baby, pets, or health/respiratory issues.
You decide what your priorities are, and pick the appropriate chassis. There are some really sweet motor homes being built exclusively on the Sprinter chassis, such as the Winnebago Navion and View.
The Ford Transit Chassis
This chassis is increasing in popularity in the smallest sizes.  According to Ford's website, the Transit DRW chassis is offered in the 156", and 178" wheel base, and is rated as high as 10,360 GVWR.  Ford offers a motor home package specific for the RV industry.  It's diesel engine compares to the Sprinter in power and fuel economy, but is more affordable and is easily serviced at Ford service centers, just like the E350 & E450.  The cab has a lower stance than the Sprinter making it much more friendly to get into and out from for people in their later years.  Entering and exiting is more like a mini-van rather than a standard van.  The Transit's lower cab also offers roomier over-head bunks that are easier to access.
Ford recently discontinued the diesel engine, replacing it with a gasoline 3.5L-V6 twin-turbo direct-injection engine.  This eliminates a lot of diesel-related draw-backs, but I understand the fuel economy is not much better than the E350's large V8.  So if fuel economy is your primary reason to consider a Transit, know what you are giving up for only a 10% improvement.  Also consider the reliability of a large simple naturally aspirated engine versus a complex twin turbo engine with high pressure direct fuel injection.
The Dodge Promaster 3500 Cut-Away Chassis
This front wheel drive chassis is another recent entry in the RV industry.  I am concerned over it's lack of load capability as reflected with single free-wheeling rear wheels.  I have been reading posts written by new Promaster RV owners stating they are over-weight with just two people, some personal effects and food.  They say they can't carry water and never a 3rd person.  I would not be comfortable with such a limited load range in a B+ or C.   This chassis is perfect for class "B" motor home market because being front wheel drive, there is no drive shaft or rear differential. The extra undercarriage space gets well utilized by the outfitters with more batteries, bigger waste & propane tanks, and other under-the-floor utilities.
The Chevy 4500 Chassis
Unfortunately this chassis is not more popular, primarily because GM sort-of gave up on competing with the Ford E450.  It offers more interior comfort than the Ford, but not as much as the Sprinter.  It's power & weight ratings are a little less than their Ford counter-parts making them a great chassis for all but the heaviest of class Cs.  One thing to keep in-mind, if you are counting inches in storing your rig, the Chevy is a little longer than the Ford by a number of inches which was critical for us with our garage as seen HERE with our Ford 2007 E350 rig.  That could be the reason why the Chevy has a little more interior driver/passenger leg room.
The E350 & E450 with V10 engine was discontinued some years ago.  Today the majority of class B+ and C motor homes are built on one of them with 7.3L-V8 engine for a number of very good reasons.  They have more power and load capability than the other choices.  Ford approves outfitters to modify the chassis to increase or decrease the wheel base which provides motor home companies a lot of design freedom.  Ford has off-the-shelf components that work with the wheel base modification.  So if you need a new drive shaft, fuel line, brake line, parking brake cable, wire harness, whatever, Ford has them available.  Finally, the E350 & E450 chassis are competitively priced.
Engine Power Ratings of Ford, MB-Sprinter, Chevy, and Dodge
Ford E450 - 7.3L-V8, 325hp, 450ft
Ford Transit - 3.2L-I5 diesel, 185hp, 350ft  (3.5L-V6 twin-turbo direct-injection 310hp, 400ft)
CLICK HERE for Ford Transit and E-Series Motorhome Package Specs.
Mercedes Sprinter Diesel - 3.0L-V6, 188hp, 325ft
Chevy 4500 - 6.0L-V8, 323hp, 373ft
Dodge Promaster - 3.6L-V6 (GVW only 9,300 pounds)
Click on the video below for a slide-show presentation on the construction of a Phoenix Cruiser and turn up your volume. It was made in 2007 and updated a year later. As old as this presentation is, Phoenix Cruisers are still made this way today.
I feel this presentation teaches so much, especially about hidden things that unsuspecting buyers would never think about.
 THE MAKING OF A PHOENIX CRUISER MOTORHOME
FRAME RUST
This is never discussed, but must be considered, especially with older motorhomes.  The condition is present if the rig was often exposed to winter road salt, or always stored adjacent to an ocean with salt in damp air.
If you look up under the rig and see a rusty frame, but the rust looks like rough sand paper, the frame is NOT compromised.  Just plan to address it with a product like POR-15.  BUT, if the frame has flaking rust, if you hit the frame hard with a hammer and rust flakes fall to the ground, I advise to kindly walk away.
Many years ago now, I bought an 12 year old, low mileage Ford Ranger pickup truck that had flaking frame rust.  I ended up removing the bed and banged off all the loose rust, then sealed the entire frame with POR-15.  Soon after the restoration project, I bought 5 potted trees from Home depot.  The weakened frame "gave" enough making the bed contact the cab, surely evident that the remaining good steel was insufficient to handle what I considered to be a reasonable load.  Motorhomes carry a max'd out load so if the chassis frame is compromised, the house is keeping the frame together, a very bad situation to avoid.
WEIGHT OF THE MOTORHOME DURING TRIPS
In the longer lengths, especially over 28 feet with multiple slide-outs, the weight of the rig with a full tank of gasoline, "X" amount of gallons of fresh water, people, food, gear, etc. almost surely over-loads the 6 tires, most especially the 4 rear tires.  Regardless of the size of your class C, during a trip, with everyone sitting in their usual seats, have your rig weighed at a truck stop after you have filled up with gas.  The cost is around $20.  The front and rear axles get their own weight measurement.  With your axle weight numbers, use THIS CHART to determine what your tire pressure should be.  My general rule of thumb is that if you require 75 PSI or more in the tires of either axle, then you should consider commercial grade 121-C rated tires for that axle.
Most motorhome manufacturers do not give enough consideration to the weight of the motorhome under real live conditions.  The chassis often carries more weight than the chassis manufacturer's rating.  The tires are the weakest link, most vulnerable to being overloaded resulting in a tire blowout.  A rear tire suddenly blown, acts like a gladiator's spiked ball on a chain, and destroys everything around it before you come to a complete stop.  The RV floor often gets damaged along with other things in the area.  Repairs to the floor are "patchy" at best.  A front tire blowout is extremely dangerous for you could loose control of the motorhome.
« Last Edit: October 24, 2026, 11:13:52 am by Ron Dittmer »
bobojay
  • 102
  • Model: None
  • ExtColor: Desert Sand-Lower
Re: Ron's Tips For Class C /B+ Shoppers
« Reply #1 on: September 08, 2014, 03:49:40 pm »
Ron, the biggest single reason the Chevy/GMC 35-4500 cutaway chassis is not as popular as the Ford E series is because Ford is EXTREMELY aggressive in their fleet marketing and pricing. Same as they are in construction with the F series and the public safety market now with the Taurus & Explorer.
Just because they sell a lot of units to these markets doesn't mean they are any better......
Bob & Sharon
bentgypsy
  • 13
  • Location: NM & CO in the summer. Patagonia, Arizona in the winter.
« Reply #2 on: September 08, 2014, 05:29:54 pm »
Right on Ron:  prior to buying  my Ford PC 2350 last fall, I owned an 06' sprinter RV. I like to do small town and wilderness camping. But try finding a sprinter certified mechanic in even a good size town can be challenging! I didn't mind so much replacing the resonator a couple of times, but when I had to buy a reconditioned transmission, It was the last straw!  Other problems I had: tendency to overheat on mountain passes and using precious propane for the generator. It wasn't worth the better mileage and maneuverability.
So Ron, what's debatable about what you said above? Idling the Ford E350?
Since I'm selling my PC 2350, it doesn't mean I'm unhappy with it.  I just need to get off the road--my aging and problematic bod gets priority.
Steve
bobojay
  • 102
  • Model: None
« Reply #3 on: September 08, 2014, 11:35:29 pm »
Here's the webpage for the new Ford Transit cutaway that all the RV makers will be switching to sooner than later. http://www.ford.com/commercial-trucks/transitchassis/
I have driven 5 different of the van version of the Transit with all 3 of the engines. I was very impressed with this new vehicle's comfort and ease of driving, not to mention the diesel and EcoBoost versions
Bob & Sharon
« Reply #4 on: June 14, 2017, 06:54:48 am »
I updated my post to reflect current day information, and figured it doesn't hurt to bump it up for shoppers to stumble on it easier.
« Reply #5 on: February 18, 2019, 07:15:35 pm »
Sorry, but I am bumping this up so I can find it easier to update it.
RonJ
  • 126
  • Ron & Pilar
  • PurchDate: 10/2020
  • ModelYear: 2020
  • ExtColor: Greystone/Custom
« Reply #6 on: September 23, 2019, 09:09:09 pm »
Great article Ron.
RonJ
« Reply #7 on: September 24, 2019, 01:42:35 pm »
Great article Ron.
Thank you Ron J
Ron D
TheLuvShack
  • 143
  • PurchDate: October 2016
« Reply #8 on: September 24, 2019, 06:02:41 pm »
Thanks Ron D.! Very well written.
I've forwarded your tips to several folks I know who were looking for a Class C. Very helpful.
