Queen gel bed electric sofa
  • 0 Replies
  • 11753 Views
The Bear Den
  • 2
  • I Love Camping
  • PurchDate: August 1, 2014
  • IntColor: maple, beige
  • ExtColor: custom full body gold
« on: September 01, 2014, 09:28:52 pm »
I found a quick easy way to make the electric Queen gel sofa bed.  I got a short Queen mattress pad, fitted top and bottom short sheets.  After putting the fitted pad, then bottom sheet over top of sofa, pull out the extensions, insert middle hold piece then extend sofa.  Pull mattress pad and sheet over end. Pull top sheet over bottom (1st time use).  After a good nights sleep just take all three bottom corners at each side (top sheet, bottom sheet, and mattress pad) fold inside out corners and fold up to sofa . Push extension it. Retract sofa and fold top corners inside out and down over bottom half. Fold sides  inward to middle and put into a plastic box in cabinet with pillows and blanket if used.  It just come out, unfolds  put on top and repeat.   It only takes about 3 mins to set up or put bedding away.   :)
Paulette and Steve
and the bears
Steve and Paulette
and the Bears
