Protecting exposed plumbing inside cabinet
  • 13317 Views
AMW
  • 98
  • 2015 2100-stretch
  • PurchDate: July/2014
« on: August 16, 2014, 01:31:32 am »
The plumbing for my fresh water fill runs along the inside back of the cabinet under my cooktop.  That cabinet has a good tall space and I wanted to store my gallon jugs of drinking water in it, but I didn't want them to slide into the plumbing when we're going down the road.  There are probably better carpentry solutions to this problem, but I had to do something quickly with materials at hand, so I built a guard around the plumbing with some scrap PVC and fittings that I had.  It was quick, easy and it's light and strong. It's not actually attached to anything, but rests securely against the back and sides and doesn't touch the plumbing.  The pieces aren't glued, just pushed together, so I can pop it apart and remove it easily if I need to.  I might put a closetmaid shelf on top of it for something like a roll of trash bags or such.
Ann W.
Re: Protecting exposed plumbing inside cabinet
« Reply #1 on: August 16, 2014, 08:45:15 am »
Nice - it's great to gain large item storage space.  I like the idea of a shelf on top too. hithere
Sue
« Reply #2 on: August 18, 2014, 04:05:52 pm »
Cute!
If you later get more ambitious, you could box in the filler tube to create a shelf above.  Add a tall lip to prevent things from sliding off during braking.
Every PC has little hidden areas that could be utilized for additional storage.
« Last Edit: August 18, 2014, 04:10:33 pm by ron.dittmer »
