Tire Pressure: 2014 PC2350 loaded
  • 1 Replies
  • 7347 Views
bentgypsy
  • 13
  • Location: NM & CO in the summer. Patagonia, Arizona in the winter.
« on: June 19, 2014, 01:07:00 pm »
Running close to 70 psi in rear tires, 65 in front.  Haven't weighed rig recently but I'm a full timer with lots of extras like solar panel and electronic jacks.  Also have a full booze cabinet and tow a car (Honda CRV, 3400 lbs.).
At what psi do you keep the pressure on your 2350 tires?
Re: Tire Pressure: 2014 PC2350 loaded
« Reply #1 on: June 19, 2014, 07:54:28 pm »
I am glad you asked this question.   I will be very interested to see the answers that are posted.   We have had our 2013 2350 for less than a year so we are still learning about it.  I run 70 Front, 75 Rear when cold.   In hot summer weather I check the pressure every few hundred miles on a long trip and may adjust downward a bit.   When you are going down an interstate and it is in the 90s or more, you will really pick up some air.
