Macerator dead
  • 9 Replies
  • 12739 Views
dickreid1
  • 163
  • PurchDate: Feb. 2012
Macerator dead
« on: November 30, 2013, 07:12:38 pm »
This morning I was all set up to dump, switched on the macerator pump and nothing.  No hum. No click. Nothing.
Dumped the old fashoned way.
Ok, we are back home now. I will have time to trouble shoot.  Give me some ideas like: where is the fuse? Connector? How to clear jam? How to test the motor?
Thanks and happy thanksgiving.
Dick
yankeeflyer
Re: Macerator dead
« Reply #1 on: December 01, 2013, 06:43:47 am »
I just fixed,mine last month.First look behind the cabinet with the macerator switch is.You will have to crawl under the vehicle to access this,remove the two electrical spade connectors from the switch.With a small piece of electric wire,momentarily jump the two spade clips together.If the motor runs,then head to the auto parts store and buy a new switch.If you're close to me in Satsuma,Florida,I'd be happy to help you repair it.  :)(:
dickreid1
  • 163
Re: Macerator dead
« Reply #2 on: December 01, 2013, 09:03:40 am »
Good idea.  I will try it first.
Thanks for the offer, but Palm Beach County is too far from Satsuma to be practical.
Dick
yankeeflyer
Re: Macerator dead
« Reply #3 on: December 01, 2013, 01:38:02 pm »
Good Luck!! I'll be heading for the Keys on Dec 11th to escape the cold up here in northern Florida!! ;)
JackD
  • 231
  • PurchDate: 2017 (latest)
  • Model: 2350 Sprinter
Re: Macerator dead
« Reply #4 on: December 01, 2013, 05:43:18 pm »
Have you tried turning the screw in the back of the motor? Sometimes it gets jammed with paper, etc. And you need to turn it manually to get it started.
dickreid1
  • 163
Re: Macerator dead
« Reply #5 on: December 01, 2013, 07:33:11 pm »
Jack,
Like what you do with a garbage disposal I suppose.  I will check the back side for how to do this.
Thanks,
Dick
dickreid1
  • 163
Re: Macerator dead
« Reply #6 on: December 02, 2013, 12:53:29 pm »
OK. It's working now.  Switch was ok.  Removing the end cover and turning with a flat-blade screwdriver cleared whatever was in it. Good lesson. Thanks guys.
yankeeflyer
Re: Macerator dead
« Reply #7 on: December 02, 2013, 01:32:37 pm »
Easy Peasy!! 2o2
JackD
  • 231
Re: Macerator dead
« Reply #8 on: December 02, 2013, 04:53:21 pm »
That's often the issue with them, and a lot easier than messing with wires!!!
Good luck & enjoy,
Jack
BarbRN
  • 134
  • PurchDate: May 25, 2013
  • IntColor: beige
  • ExtColor: tan
Re: Macerator dead
« Reply #9 on: December 02, 2013, 07:37:47 pm »
 2o2 I love happy endings!
