Electric couch?
  • 8602 Views
Shipper
  • 128
  • Cadillac Mountain
  • PurchDate: 04/2013
  • IntColor: Maple and Grey
  • ExtColor: Dusk
Electric couch?
« on: July 25, 2013, 10:18:07 pm »
Anyone know the best way to get the foot to lock back on the electric couch? It unlocks easy enough, but can't get the lock to hold when pushing the foot back. Thanks for any help!
jampodd
  • 40
  • PurchDate: 11/2012
  • IntColor: sunlit
  • ExtColor: sunlit
Re: Electric couch?
« Reply #1 on: July 26, 2013, 03:11:25 pm »
I just had that problem also. What's happening is the cable is sticking a little. Pull the foot piece all the way out and look under the couch, you'll see where the cable ends. I sprayed it with some dry silicone and kept working both ends of the cable with my hands. Seemed to work. I think I had to open up the slide out to give myself more room.
Jim
Jim Poddany - 2552
bhgareau
  • 111
  • PurchDate: 05/12
  • IntColor: dusk
  • ExtColor: sterling
Re: Electric couch?
« Reply #2 on: July 26, 2013, 06:32:07 pm »
 We also had the same problem. In addition to the silicone treatment check the alignment of the shaft that goes into the rear catch. We had to make a minor adjustment and it has mostly fine since then although it will occasionally pop loose on rough roads. Good luck!
