Macerator Pump FUSE
  • 1 Replies
  • 7241 Views
yankeeflyer
Macerator Pump FUSE
« on: July 24, 2013, 07:58:30 am »
Where is the macerator pump fuse??? I give up checked all fuses,can't find it and I know that there has to be a fuse somewhere.  pyho  :help
Re: Macerator Pump FUSE
« Reply #1 on: July 24, 2013, 04:02:04 pm »
I did a quick check on our 2012 2551 but did not see an obvious fuse.  I know it should be within 18" of the power supply and should be a dedicated  12v 20 amp fuse.
Do a search on MACERATOR in the forum.  You might find something related to the problem you have.  A jammed pump may look like an electrical problem.
