Trick to locking the spare tire cover?
  • 13312 Views
Shipper
  • 128
  • Cadillac Mountain
  • PurchDate: 04/2013
  • IntColor: Maple and Grey
  • ExtColor: Dusk
« on: May 25, 2013, 08:16:20 am »
The spare tire cover seems mounted correctly, but when I lock it the handle doesn't seem locked. Shouldn't the handle stay flat in the down position when locked? I can raise it up whether locked or not. Thanks for any help!
Bob Mahon
  • 547
  • PurchDate: 6/2011
  • IntColor: Tan/Gray/Cherry
  • ExtColor: Lower Slate Gray
Re: Trick to locking the spare tire cover?
« Reply #1 on: May 25, 2013, 10:15:36 am »
Mine will raise too. Try turning it when locked.
Frank
  • 76
  • PurchDate: April 2012
  • IntColor: green
  • ExtColor: green
« Reply #2 on: May 25, 2013, 10:23:08 am »
  Had the same problem, found if you push hard on the center
  while turning the handle an extra turn or two, it will stay tight.
Frank & Dee  CHEERS!!
lmichael
  • PurchDate: May 15, 2012
  • IntColor: Sterling
« Reply #3 on: May 27, 2013, 04:56:31 pm »
The handle can be raised when locked, but it should not turn.
« Reply #4 on: May 28, 2013, 10:48:12 am »
Yes....when locked the handle can flip up and down, but should not turn.  We all like to store the handle in the down position because it looks right.
I also noticed with our spare tire lock set, it will lock in only one of the two handle positions.  If the key won't turn,  turn the handle another half-turn.
I really love the tire storage design.  I never seen another motor home with a better setup.  Easy to get to, well protected from elements and thieves, looks great, takes no valuable space, never in the way.....a true winner.
« Last Edit: May 28, 2013, 11:01:34 am by ron.dittmer »
Shipper
  • 128
  • Cadillac Mountain
  • ExtColor: Dusk
« Reply #5 on: May 28, 2013, 12:51:50 pm »
Thanks for the replies! I can't try my handle because my RV is at the Ford dealers for a fuel line leak. It's been there for over a week, but all parties (Ford, Lippert, and PC) are working on it. Just waiting for someone to solve the problem that the Ford guy has in getting the right parts that he thinks he needs.
Shipper
  • 128
  • Cadillac Mountain
  • ExtColor: Dusk
« Reply #6 on: May 31, 2013, 09:15:21 pm »
Just got my PC back from Ford service and checked the handle. Thanks for the reply!
