Poll
Is this just something that is associated with driving large trucks.
0one
0 (0%)
two
0 (0%)
three
0 (0%)
Total Members Voted: 0
Steering question
  • 5 Replies
  • 10324 Views
ge_montana
  • 93
    • East of Yellowstone
  • PurchDate: January 4, 2012
  • IntColor: green
  • ExtColor: green half
Steering question
« on: June 19, 2012, 06:30:16 am »
Now that we have the Fit hooked up with our Road Master hitch, i notice that the PC seems to require a secondary response after a curve while driving at road speed. This secondary motion requires a series of alternating, but decreasing in size, movements of the steering wheel from right to left. I have installed Bilsteins, and Safe-T-Brake steering damper. I do not have the same motion when the Fit is not attached.
My bride thinks it may be due to the play in the hitch which allows the ends of the Roadmaster arms to move as much as 2 inches to be the problem. Today i will add a U bolt to take the play out.
Today i am having the block removed on the diver side rear springs that Kermit says is not needed. That block resulted in a lean in to the right of the vehicle and i am thinking that ean may be causing the problem.
Another solution could be to add Helwigs stabilizer bars.
Any suggestions?
Greg Matthews
Photographer
EastOfYellowstone.com
Re: Steering question
« Reply #1 on: June 19, 2012, 08:38:40 am »
Hi ge_montana,
Internet suspension diagnosis is always to be taken with scrutiny.  With that understood here is my input.
You have a newer model 2551 on an E450 chassis, meaning that your chassis is about the least loaded as an E450 could be.
Heavy duty front and rear stabilizer bars would reduce side-to-side rocking motion.  But if your rig is not doing that while you compensate, your compensation troubles might get resolved with a rear trac bar.  The trac bar reduces horizontal side-to-side motion referred to as tail-wagging.  Either type of such motion can require steering compensation as you describe.  Determine what type of behavior your rig has, rocking or tail-wagging.  Then consider the appropriate resolution.
You are correct to address the play in your tow bar through one of these (called a Quiet Hitch) and see if it helps.
Be sure your tow bar is horizontal.  If not, buy something like this to make it so, and get the right height as they are sold in different off-sets.  A tow bar on an angle greater than a 2" height difference between motor home and tow vehicle can create notable bucking.  The greater the difference, the greater the bucking action.
Though it is not the problem you describe, it is worth mentioning since you brought up the play in your tow bar.  Adding a riser will introduce a lot more play in the tow bar, so be sure to use two Quiet Hitch U-Bolts there.
« Last Edit: June 19, 2012, 08:50:58 am by ron.dittmer »
  • 1165
« Reply #2 on: June 19, 2012, 09:24:45 am »
I agree, the first step is to remove the play in the hitch and make sure it is level.
I use the Draw-Tite J-Pin Stabilization Pin and Barrel Lockset.  It locks everything together; there is no waggle. Here is a link with good pictures and video.
http://www.etrailer.com/Locks,Hitch-Accessories/Draw-Tite/63201.html
Here is a link to a previous post dealing with Tow Bar Alignment
http://forum.phoenixusarv.com/index.php/topic,569.msg3599.html#msg3599
« Last Edit: June 19, 2012, 09:28:26 am by Barry-Sue »
  • 550
  • PurchDate: May 5, 2012
« Reply #3 on: June 19, 2012, 02:25:42 pm »
Barry and others:
I utilize the "J" style locking pin (and find it to be the best style) to take the movement out of the hitch but please be aware that the hitch reciever that PC is using now does not have the extra hole for the small tip on the J hook to go into...I think they are using Draw Tight hitches now.  I had to drill the second hole myself on my new  late production 2012 3100 and trust me that stock does not make for easy drilling so check your reciever for that second hole!  best of luck.  Ron
Ron Goodspeed
  • 1165
« Reply #4 on: June 19, 2012, 04:19:39 pm »
I had the same issue.  When we picked up our PC I brought the bit and had the factory drill the hole and then they painted it.  Their air powered drill made it look easy.
ge_montana
  • 93
  • IntColor: green
« Reply #5 on: June 21, 2012, 06:08:05 am »
Thanks Ron, what i have is the wag, and i believe the Henderson and the U-bolt attachment to the receiver are the issue. By the way i found the following as a good discussion:
http://www.rvforum.net/miscfiles/MH_Steering_Handling_%20Primer.pdf
Greg Matthews
Photographer
