RV park Hookup
  • 7933 Views
jlid51
  • 9
  • PurchDate: Feb 2012
RV park Hookup
« on: April 15, 2012, 12:28:36 pm »
Hi Guys
When hooked up at an RV park and if you leave the grey water valve open will it drain thru the sani-com without the pump on.  I guess the question can you gravity drain grey water thru the sani-com system.
Jerry
Re: RV park Hookup
« Reply #1 on: April 15, 2012, 03:14:53 pm »
There is small tube that you can see on top of the motor which is to let the gray water bypass the pump. The gray tank will need to be almost full before it bypasses over the motor and then it is real slow.
gl1500
  • PurchDate: May. 2014
  • ModelYear: 2551/2014
  • ExtColor: Cafe'
Re: RV park Hookup
« Reply #2 on: April 15, 2012, 06:33:43 pm »
I bought a replacement cap for the large back-up  drain with a standard hose fitting.  I carry a gray hose for use in a park when we will be there for several days.  Hook up the hose to the drain fitting, open the gray tank and have the hose placed in campground sewer drain.  There is also a fitting to hook the hose to that fits in the drain to it covered and sealed as required by some areas.  Never need to worry about over filling your tank.  If you are going to need to dump the black tank, close the gray tank a day early to build up some gray for flushing the macerator system and disconnect the hose and recap the fitting prior to dumping.
