Fuse and Breaker Labeling
  • 27851 Views
« on: April 09, 2012, 09:15:38 pm »
This winter I had to look at the 12V fuse panel on our 2012 2551 and found it a little hard to read.  Once we got home I verified and labeled each fuse.  The original labeling was done with water soluble ink and was very easy to remove by just wiping it with a damp cloth.  Also, did the same thing for the 120V circuit breakers.  Sure makes it a lot easier to read and find the right circuit and it was very esy to remove the door panel to work on it.  The attached photo shows the 12V fuse panel before and after labeling.  I just used an old label maker but it could have been just as good to write them in neatly with a permanent felt tip.  Also, if you are going to rewrite yours, verify them first since they may not all be wired the same.  For instance, we had a 12V outlet installed in the bath and it is fuse number 8.
Note: Fuse 9 label has been corrected.
« Last Edit: April 09, 2012, 09:21:36 pm by Barry-Sue »
aimee
Re: Fuse and Breaker Labeling
« Reply #1 on: April 11, 2012, 12:47:09 pm »
Oh, I like this.   2o2 I live in a very old 3-story Victorian home with two giant boxes full of breakers.  I am a big fan of easy-to-read panels. I printed mine onto small address label sheets, but a label maker makes quick work of it.
wideglide
  • 86
  • PurchDate: 6/2026
  • ExtColor: gray
« Reply #2 on: August 03, 2026, 02:43:45 pm »
This is exactly what i needed. My new to me 2011 PC 2350 has the hand written labels just like this. IM quite certain written by the same person as the writing looks identical. Ive been looking for any sort of wiring diagram or schematic for troubleshooting and relabeling everything. I would venture to bet that my fuse panel if not identical is close enough that this will at least help me decipher what each fuse is for as the handwriting is horrendous. When at some point i figure it all out i will post my results also.
« Last Edit: August 04, 2026, 09:07:43 am by wideglide »
