Improvements & Enhancements, 2007 PC-2350
  • 101 Replies
  • 436889 Views
Re: Improvements & Enhancements, 2007 PC-2350
« Reply #90 on: September 20, 2018, 09:49:43 am »
Added #40
Something I did so long ago but I never included.
ExStarlifter
  • 74
  • PurchDate: June 2018
  • ExtColor: Sandstone
« Reply #91 on: October 15, 2018, 12:58:08 pm »
Wow!  Couldn't pass up some of these!  The Hanging Gravity Sewer Hose Storage Tube is currently (as of 10/15/18) on sale for $43 at Camping World.  If you can find a way to spend $7 more (and you know you will), shipping is free for all the items you purchase.
« Reply #92 on: March 06, 2019, 03:29:41 pm »
Added #41 Shock Absorber Evaluation
« Reply #93 on: September 10, 2019, 11:53:16 pm »
Added number 42 in the original post.
« Reply #94 on: May 19, 2021, 08:58:05 am »
Added #43 and #44 to the original post.
« Last Edit: May 19, 2021, 03:58:38 pm by Ron Dittmer »
« Reply #95 on: June 05, 2021, 09:54:08 pm »
Added #45  to the original post.
66 Degrees North
  • 1
  • PurchDate: Oct 2023
  • IntColor: Wheat
« Reply #96 on: February 26, 2024, 07:24:23 am »
I figured the shocks should be where I start...as my PC has indeed added some of your other suggestions (PC or Previous Owner).   In the Bilstein Heavy Duty B6 shock there are two models -Heavy Duty Standard and Heavy Duty Comfort.   Did you opt for the Standard or Comfort and why?  I have a 2018 PC 2351.  Thanks for the answer and your other how-to-solves.
66DegreesNorth
« Reply #97 on: March 02, 2024, 06:54:53 pm »
Hi 66DN,
I debated the same as you back in the day.  I decided to go with what you call "Heavy Duty Standard."  Mine are NOT the "Comfort" version.  The front shocks these Bilsteins replaced failed badly at the top mount area.  I was worried of introducing a more rough ride with the heavy duty Bilsteins but took a leap of faith based on reviews.  In the end, I am extremely happy with my choice.  The change in comfort with regards to harshness is truely negligable but the improvement in front stability was tremendous which increased comfort in other ways.
If you have not found my write-up on this subject, here it is for your convenience.  It includes many pictures.
https://forum.phoenixusarv.com/index.php?topic=3580.msg30529#msg30529
A change of subject here, but it is somewhat related.  Check it out.  You might do good, or you might do bad from doing something similar.  I changed front coil springs to soften my front ride.  I DID NOT do it because of my choice in Bilstein shocks.  For us with our PC's load and load distribution, I would have done it regardless of the shocks installed.
https://forum.phoenixusarv.com/index.php?topic=4168.0
I feel I am in a very good place with the ride and handling of our PC, but.....  I have one more matter to look into that is related to my Safe-T-Plus's cantelevered mounting bracket.  The pressure applied from this extra long bracket, on the end of our E350's frame where it mounts, is slightly twisting the end of the frame.  I believe that slight twist introduces a little of "the floaties" in the steering wheel.  I will look into strengthening the E350's "C" channel frame there via bolting on more steel.
Since the E350 chassis has a slightly thinner gauge "C" channel chassis frame than the E450, I would assume people with an E450 see this less of an issue, or it may be non-existent.
« Last Edit: March 02, 2024, 09:22:12 pm by Ron Dittmer »
wideglide
  • 86
  • PurchDate: 6/2026
  • ExtColor: gray
« Reply #98 on: July 29, 2026, 09:56:22 am »
Thanks so much Ron,
This is a great list. I will copy you on many things from here.  My black sewer hose tube arrived yesterday. The skid roller wheels are saved on amazon still to buy. Ill post my results when i get them installed.
« Reply #99 on: July 29, 2026, 12:18:31 pm »
You are welcome!
My 2007 2350 has the outdoor storage compartment located just behind the rear tires.  I believe, the following year, Phoenix shifted the compartment all the way back rearward.  I don't know how this difference will affect the mounting of your storage tube.  Hopefully, you can figure it out.
Under my 2007 storage compartment is supporting angle iron.  Hopefully, you have something similar in the same area, to attach this end of the tube to.
Amsoilman
  • 71
  • PurchDate: 2024
  • IntColor: Grey
  • ExtColor: White Grey
« Reply #100 on: July 29, 2026, 06:23:07 pm »
I installed mine just in front of the drawer
Bolted an angle iron to the frame then I welded 2 cross pieces to mount the tube to.
RecPro RV Extendable Waste Hose Carrier Super Slider Storage Tube (33" - Extends to 60")
Dystevens
  • 11
  • PurchDate: 8/8/2025
  • ModelYear: 2021
  • IntColor: Light Oak
  • ExtColor: Gray
« Reply #101 on: September 15, 2026, 06:40:05 pm »
Ron, great post! You have definitely given me some customization ideas.
