Pull-up Shelf Under Stove - Adapted to Side or Bottom Opened
  • 14951 Views
Hi.....
Someone gave directions in how to convert the pull-up shelf under the stove to open two directions. I've printed the directions and think I understand how it would work. I'm assumingthe following: one piano hinge is attached behind the L-Plate at the top, and the other piano hinge is attached just to the L-Plate and shelf/door. One question: How is the brace attached when the shelf is in the up position? Is it a hook that is unlatched to put it down?
I cannot find a "L-plate" large enough to do the job. Any ideas where I can purchase one would be helpful.
Sorry to make a new topic; I don't seem to be able to locate the original one.
Thanks for any help you can give.
Donna
  • 5744
Re: Pull-up Shelf Under Stove - Adapted to Side or Bottom Opened
« Reply #1 on: July 24, 2009, 04:04:37 pm »
It is in this initial post, described in the 4th paragraph, but someone else.
http://forum.phoenixusarv.com/index.php?PHPSESSID=66865124f751f423ec778a09112c221c&topic=41.0
« Reply #2 on: July 24, 2009, 09:34:52 pm »
Thanks for the link, Ron.....Appreciate the help.
