Black Water Tank Switch not working (Dead)
  • 2 Replies
  • 138 Views
Toorusty
  • 19
  • PurchDate: Apr 2, 2019
  • IntColor: Off White
  • ExtColor: Custom
« on: November 25, 2026, 04:12:28 pm »
My RV (2015 29D) was mid-tire deep in water last week in the FL floods. Everything seemed to be ok so we took off for our Thanksgiving trip. After we were set up in the park, I found that the switch for the black water tank is dead (no clicks or groans). . I checked under the fridge for a blown fuse but all are good. The gray water switch works fine.  It appears that the switches were submerged. I have alternate facilities but would like to open the black water tank. Is there an easy way to manually open the black water tank?
« Last Edit: November 25, 2026, 04:53:24 pm by Toorusty »
  • 5750
Re: Black Water Tank Switch not working (Dead)
« Reply #1 on: November 26, 2026, 12:13:32 am »
Not sure on a 2015, but I seem to recall (my memory is shady) on our 2007 2350, the tank valve "T" handle attaches to the actuator.  Loosen a screw to move the "T" handle manually.  Naturally it involves getting under the rig.
You might be able to move the actuator itself without doing anything else, but I have not tried it.
Since your switch is dead, you can't break it further.  For a quick solution, I would be tempted to open it, clean it, let dry, and reassemble.  If time is on your side, just buy a replacement from Phoenix real cheap.
One more point to make: Your switch might be fine.  The actuator mechanism may have gotten damaged if it was also under water.
I see being sold, waste tank valves with remotely mounted "T" handles on a length of cable.  Having a pair of "T" handles where the switches are, would technically simplify the sanicon system.  I feel changing to that setup would be for the better.  Electrically activated tank valves are impressive, but is that really the best valve control method?  Maybe PCs don't have consistent dimensional clearances across models, for cabling.
« Last Edit: November 26, 2026, 02:13:53 am by Ron Dittmer »
Toorusty
  • 19
  • ExtColor: Custom
« Reply #2 on: Today at 11:59:50 am »
Thanks for the reply. Wasn't able to find any way to manually open the valve. Going to order a new switch and go from there.
