Replacement for converter/charger for 2015 2350
  • 1 Replies
  • 12 Views
barko1
  • 3
« on: Today at 06:10:31 pm »
Wanting to upgrade so I can charge Lithium. What is a reasonable plug and play for the Intertec 5300 I have now?  Thanks
LRUCH
  • 235
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
Re: Replacement for converter/charger for 2015 2350
« Reply #1 on: Today at 09:08:06 pm »
The intertec 3500 is not able to fully charge lithium batteries, which only at 14.7 volts.
Here's the specs I found on it:
DC Output Voltage: 13.2 to 14.0 Volts DC (nominal ~13.85V max at no load)
Even though lithium batteries voltage peak at 13.6V, they need 14.6 (or 14.7 according to some sources) to finish charging the top 15%.  It also needs higher (than lead acid or SLA) voltage and amperage to charge in general.  Since lithium will absorb current at a high rate, it is likely to over load the intertec.
Larry
Larry
