Trix - L - Start
  • 1355 Views
CapeCodPC
  • 3
  • PurchDate: 8/11/2026
  • ModelYear: 2021
  • IntColor: Tan
  • ExtColor: Brown
Trix - L - Start
« on: August 29, 2026, 11:36:22 am »
New owner here.
We have a 2021 2351 D that has a Trix - l - start unit in the engine compartment. This unit started beeping whenever we start the engine and continues beeeping even After the camper is shut off. I can reset this by disconnecting the battery but will start again as soon as we used the unit. I have taken it in for service and have been told I need a new battery (which I expected) the service department has told me that they are recommending that I disconnect the Trix - l start unit that is serving no purpose but to drain the battery.
Any information on this subject will be appreciated.
LRUCH
  • 234
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
Re: Trix - L - Start
« Reply #1 on: August 29, 2026, 12:09:58 pm »
Disclaimer, I've never seen one of these, but a quick search in Google offers this advice for the beeping...
Common Causes and Fixes
Low Starting Battery:
Your chassis battery voltage may have dropped below the warning threshold (typically under 11.9V), signaling that it is heavily discharged or failing.
Loose or Corroded Connections: Dirt, corrosion, or loose ring terminals on the house, chassis, or ground wires can interrupt the charging flow and trigger a false or low-voltage alarm.
House Charger Failure: If your shore power converter or solar setup is not actively charging the house bank, the system cannot maintain the starting battery.
I see that it has some indicator lights. Which ones are on?
« Last Edit: September 03, 2026, 12:21:37 am by LRUCH »
Larry
CapeCodPC
  • 3
  • ModelYear: 2021
  • IntColor: Tan
  • ExtColor: Brown
« Reply #2 on: September 03, 2026, 07:19:10 am »
Thanks Larry, I believe I have worked it out for now, will disconnect for now but leave in place and when I visit The Phoenix USA factory in October I'll review the system with them.
