RV Travel: RV inspector recommends the best older motorhome brands
  • 25 Replies
  • 19798 Views
LRUCH
  • 224
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • IntColor: Maple
  • ExtColor: White/Sage
Larry
  • 5717
Re: RV Travel: RV inspector recommends the best older motorhome brands
« Reply #1 on: June 13, 2025, 10:48:57 am »
Thanks for sharing that.  It is awesome that Phoenix is #7.  Unfortunately, the review does not get into detail about older PCs, nor does it cover them in the video.  In my opinion, older PCs that are well cared for & sheltered in some fashion over the years when not in use, are in great shape.  Many older PC's are short, making them easier for sheltering, so there are a few old ones out there in exceptional condition.
I personally feel mid-year 2004 is the beginning of the best PC's.  At some time during the 2004 production year, Phoenix introduced the solid strong rear wall with integrated spare tire compartment & storage compartment, and also the entry door that are both used to this very day... be it, the spare tire feature later deleted.  What was introduced back then, made the Phoenix Cruiser's structural integrity stand apart from the industry at the time.
The next threshold is the 2007 model year when a number of creature comforts were standardized.
1) A single house battery in the wall was changed to 2 batteries below floor level.
2) 110V whole house inverter.
3) Clean hands macerator waste management, with conventional method for backup.
4) Flat panel TV replaced CRT (actually introduced a year or 2 earlier)
5) Somewhere in the 2004-2007 time period, Corian counters with covers for stove & sink.
Phoenix created a slide show presentation in 2007 and updated it in 2008.  It reviews all kinds of exceptional design and construction practices that I understand, are in place to this very day.  It is surely worth watching on U-Tube here.
https://www.youtube.com/watch?v=V2Mfp-jZIR0
I don't know of any other motorhome manufactures using these same exceptional practices in electrical & plumbing, the framing of cut-outs in the walls & roof, and the construction of the floor with marine plywood, tubular framing, insulation as shown, and full-covering plastic corrugated under-protection.
The slideout mechanism of that era is very reliable which also includes a means to manually crank in the slideout if there was a failure.
Just wrapping this up with my Buyer's Guide.
New, used, or well used, when shopping for a conventional class B+ or C, the most important consideration is how it is constructed.  This post outlines construction methods which are most affordable and methods that cost more, but are built to hold up much better to the elements and also the punishment of the road.
Some motor home manufactures offer different levels of quality through their various model lines. Instead of providing a list of brands to consider, it is best to identify what "Better" is.
When shopping for a motor home, don't get distracted with "Eye Candy" and "Square Footage". You want to pay close attention to how the house is constructed.  Water infiltration is the number one killer of motor homes, rotting them away long before anything is worn out. Once water gets inside, it is like termites.  By the time you realize there is a problem, a lot of damage has already occurred. Also consider that mold & mildew can grow inside the walls which then you have a health hazard. My advise focuses on identifying a reliably well sealed motor home.
#1 BEST (Very Expensive, Can Be 1.5 times the cost of Second Best)
NO structural seam work. The brand Coach House is a fine example. It is seamless, made from a mold. The only places where water can leak is cutouts for windows, entry door, roof-top vents & a/c unit, storage compartments & maintenance access, all of which are in areas of very low stress. Because they have a seamless shell, these motor homes are not common and have a limited selection of sizes and floor plans.
#2 SECOND BEST
Common, Affordable, & comes in Many Sizes so this is my main focus
I own an example of this type.   My Rig Here manufactured by Phoenix USA.
Made in sections, but assembled in a way that greatly reduces the threat of water damage. Here are the good things you want to look for.
a) Structural Seams Away From Corners
When a motor home is driven, the house bounces, resonates, shakes, and leans countless times, representing a endless series of earthquakes. Corner seams see greater stresses than seams located elsewhere. Corner seams are more easily split, especially when the caulk gets brittle with age & exposure to the sun. One extremely bad bump in the road can instantly breach a corner seam. Seams hold up much better when they are brought in from the corners in lesser stressed areas.
b) A Seamless Over-The-Van Front Cap
A huge bed above the van’s roof is the most vulnerable area of a motor home. No matter how well they are made, that long frontal over-hang resonates when the RV is driven making it common for seams to split there, most troublesome with age & exposure to the elements.  HERE is an example, one of many water-damage threads I have read.  Scroll down in that thread to see pictures of the real damage.
The small front aerodynamic cap of a B+ design HERE eliminates the overhang which eliminates most of the resonation, along with the most vulnerable seam work.
There are a few conventional “C” Designs (big over-van bed) where that area is seamless. If you absolutely must have that huge bed, then look for a seamless bucket-like design.  The Itasca Navion is a fine example.  If your requirements are to have a large class-C with a massive over-van bed, the best example I seen was this Fleetwood Tioga model offered around 2008-2009.  It is unfortunate all class-Cs don't practice seamless cab-over area construction for it would greatly improve the class-C industry.
Increasing in popularity by many manufactures is a shallow bucket design with fewer seams located in less-stressed areas.  The Nexus Triumph is one such example.  This shallow bucket design is a reasonable compromise.
If you plan to accommodate more than 2 people, having that large extra cab-over bed will be extremely useful.
c) A Crowned Roof
Rain and snow melt runs off a crowned roof. A flat roof will sag over time, then water puddles around heavy roof-top items like the a/c unit. Water eventually finds it's way inside after gaskets & caulk have degraded from age, sun, and change in seasons.
d) Rolled-Over-The-Edge seamless Fiberglass Roof Sheathing
A single sheet of fiberglass as shown HERE that rolls over the right & left sides of the roof, down to the wall. The overlapping of fiberglass to the wall provides a good water seal and the fiberglass sheathing holds up better than roofs made of sheet rubber or thin plastic called TPO, which require more attention to keep your RV well protected.
e) A Five Sided Rear Wall Cap
A five sided back wall moves the seams around to the sides to areas of much less stress as seen HERE.  The rear wall resembles a shallow rectangular cooking pan standing on it's side.  Like the example, some rear wall sections are constructed with an integrated spare tire compartment and rear storage compartment.  Not only are they convenience features, but that rear wall/cap offers a solid double-wall for exceptional strength which is more resistant to flexing the adjoining seam work.  It helps in keeping the house together.
Don't be fooled.  Some manufactures add rear wall sectional styling which gives the appearance of a 5-sided pan design.  Though not as desirable, they are still an improvement because all the holes for lighting and such are not in the structural wall where water could otherwise get inside the house.  You can easily tell by noting the sections & seams between them and the flat back wall that remains exposed.  CLICK HERE to see an example.
f) Walls Are Either Resting On The Floor Or Fastened Against It
Common sense would say the walls should rest on the floor, but some manufactures actually fasten the walls into the side of the floor framing as ILLUSTRATED HERE.  This means the weight of the roof and walls (and everything hanging on them) rests on the fasteners.  How well will that method hold up when being driven for so many thousands of miles?  Checking for this is very difficult.  It takes a trained eye for sure.  CLICK HERE for an example of it done right with the walls resting on the floor.
Bigger Will Be Weaker
The size & floor plan you select MUST FIRST meet your needs before this consideration.
The bigger the house, the weaker the structure will be.  Consider two cardboard boxes made from the exact same corrugated material.  The smaller box would naturally be stronger.  It will be more resistant to bending, twisting, and other types of flexing.  So if you are on the fence between models, the smaller one will be your stronger choice.
Potentially Troublesome Construction
Entry level motor homes are made with seams in corners and finished off with trim, including the massive cab-over bed.  Their roof is flat and finished with rubber or TPO. They are most affordable, and come in all sizes. HERE is one such example.  If considering this construction type, keep in-mind they require more regular care with bi-annual inspections. Plan to use a caulking gun now and then. When buying a used one, consider that you really don't know how well the previous owner maintained it. Buying new or used, that construction method will be counting on you to be a good non-neglectful owner.
There are also the rare exception like the recently defunct LAZY DAZE which has seam work in the corners, but the substructure and sealing method is of the highest quality that it holds up like a seamless body.  It is also worth noting that the company never utilized slide-outs.  It's excellent sectional construction methods are not commonly found in other brands. I am no expert on this, but I'd give it a #1.5 Almost Like Best
A Caution Concerning Slide-Outs
Slide-outs are most popular.  Everybody loves the extra floor space they provide.  There are so few motor homes made without at least one slide-out.  Unfortunately slide-outs can introduce risk of water damage to the main floor around them.  Good seals work when the rig is young, but can loose their ability to seal properly as they age.  When looking at used rigs with slide-outs, closely examine the main floor around each one.  If you can lift the carpet adjacent to the slide-out and see the wood floor is a gray color, that is a sign that water gets inside.  Also, completely open the slide-out and step on the main floor adjacent to the slide-out.  If it feels soft, the plywood or chip board material underneath likely requires replacing.
Not All Slide-Outs Are The Same
Some slide-outs have a single motor system with a backup method of drawing in the slide-out in-case of a failure.  They include a hex bolt that you attach a crank onto and crank it in manually.  Since slide-outs have gotten bigger and heavier, two motors have become neccessary which requires electronics with software to keep them synchronized.  The added complexity of the over-all system dramatically increases the frequency of issues.  The worst part is, you can't crank in these like you can with most single-motor slide-out systems.  If you see a slide-out with THIS then it has the two-motor complex system.  If you see angled bars along the sides like THIS then you have identified one of the most reliable slide-out systems which includes a manual crank-in back-up.  Unfortunately, RV manufactures don't like to mix systems.  If one of their models require a two-motor system, then whether big or small, every slide-out in every model gets the same system.
Slide-Outs Containing Appliances, Sinks, And More
A slide-out with a fridge or stove, and a sink, has to extend and contract the appropriate connections.  How many in's and out's does it take until something goes wrong?  Here is a list of systems that require special consideration, if placed inside a slide-out.
110V Electrical Umbilical Cord or Cords
12V Electrical Umbilical Cord or Cords
Hot Water Umbilical Cord
Cold Water Umbilical Cord
Waste Water Umbilical Cord
Propane Umbilical Cord
Furnace Heat Duct Umbilical Cord
Coax Umbilical Cord
Speaker(s) Umbilical Cord
Location Of Slide-Outs
It is very common for a slide-out to be located directly behind the driver seat.  If you are a tall person, this can greatly limit the positioning of the driver seat when the slide-out is brought in for driving.  So be mindful of this limitation.  The condition SEEN HERE is easy to spot from the outside.
A few manufactures have angled transition walls between the van and the house that naturally sets the slide-out farther rearward as SEEN HERE.
Concern Over Bad Plumbing Practices
Once in a while, a manufacture of motorhomes will simply Build Bad.
1) CLICK HERE for a picture of the whole house water filter, and CLICK HERE for the water pump, both placed in the same compartment with all the electronics.  If anything comes loose and water sprays around inside this compartment, your motorhome is electrcially destroyed.
2) CLICK HERE and CLICK HERE to see hot and cold water plumbing lines being routed underneath the motorhome, completely vulnerable to freezing.  Summer camping at high altitude and in Canada will often see temperatures below freezing, with spring and fall being much more threatening.  Think about the ruptured plumbing you will forever deal with over this engineering debacle.
About The Chassis
The most popular is the Ford E450 with the 7.3L-V8 engine, a notable improvement in power and fuel efficiency over the 6.8L-V10 it replaced in 2020. The Ford Transit diesel & gas turbo along with the Mercedes Sprinter diesel are popular alternatives.  The GM 4500 chassis is not popular but is a very good choice for the right application. Any of the chassis mentioned made since 1998 are real good, new or used. If you plan to tow a car or trailer, be aware that the Transit and Sprinter will be least powered. People who tow with them, tow lighter and cruise slower.  Do your research if you have something specific in-mind to tow.
If considering a recent “small” class B+ or C motor home, here is a comparison between the two current primary chassis contenders, the Sprinter with the V6 diesel engine and the Ford E450 with the 7.3L-V8 gasoline engine.
Advantages Of The Mercedes Sprinter With Diesel Engine
- Offers a 30% improvement in fuel economy over the Ford-V8, when both are loaded and driven identically.
- More ergonomic driver compartment with more leg room.
- Comfort continues with a car-like feel & quiet ride.
- A grander view out the windshield
- Made by Mercedes which people are attracted to.
Advantages Of The Ford E350 & E450 with gasoline V8 engine
- Given identical motor homes both brand and model, the Ford is around $24,000 MSRP cheaper
- The Ford V8 engine has nearly a 50% increase in horse power and 25% increase in torque.
- The Ford E450 chassis handles roughly 4000 pounds more weight.
- The E450 is able to tow a heavier load.
- The E450 rear axle is significantly wider which translates to better stability.
- In most places traveled, gasoline costs less than diesel fuel
- The Sprinter diesel has limited mechanical service shops around North America
- The Sprinter diesel is typically outfitted with a propane generator.  Propane is a critical fuel for RV operations, and generally needs to be rationed when dry camping.
- The V6 Sprinter (and Transit) diesel engine is not allowed to idle for extended periods. This limitation is detrimental when you need a/c but there are generator restrictions, you are low on propane, or you have a mechanical failure with the generator or roof a/c. The Ford gas engine offers a great backup system. The V8 can safely idle for hours on end, heating, cooling, and battery charging, all valuable if you have a baby, pets, or health/respiratory issues.
You decide what your priorities are, and pick the appropriate chassis. There are some really sweet motor homes being built exclusively on the Sprinter chassis, such as the Winnebago Navion and View.
The Ford Transit Chassis
This chassis is increasing in popularity in the smallest sizes.  According to Ford's website, the Transit DRW chassis is offered in the 156", and 178" wheel base, and is rated as high as 10,360 GVWR.  Ford offers a motor home package specific for the RV industry.  It's diesel engine compares to the Sprinter in power and fuel economy, but is more affordable and is easily serviced at Ford service centers, just like the E350 & E450.  The cab has a lower stance than the Sprinter making it much more friendly to get into and out from for people in their later years.  Entering and exiting is more like a mini-van rather than a standard van.  The Transit's lower cab also offers roomier over-head bunks that are easier to access.
Ford recently discontinued the diesel engine, replacing it with a gasoline 3.5L-V6 twin-turbo direct-injection engine.  This eliminates a lot of diesel-related draw-backs, but I understand the fuel economy is not much better than the E350's large V8.  So if fuel economy is your primary reason to consider a Transit, know what you are giving up for only a 10% improvement.  Also consider the reliability of a large simple naturally aspirated engine versus a complex twin turbo engine with high pressure direct fuel injection.
The Dodge Promaster 3500 Cut-Away Chassis
This front wheel drive chassis is another recent entry in the RV industry.  I am concerned over it's lack of load capability as reflected with single free-wheeling rear wheels.  I have been reading posts written by new Promaster RV owners stating they are over-weight with just two people, some personal effects and food.  They say they can't carry water and never a 3rd person.  I would not be comfortable with such a limited load range in a B+ or C.   This chassis is perfect for class "B" motor home market because being front wheel drive, there is no drive shaft or rear differential. The extra undercarriage space gets well utilized by the outfitters with more batteries, bigger waste & propane tanks, and other under-the-floor utilities.
The Chevy 4500 Chassis
Unfortunately this chassis is not more popular, primarily because GM sort-of gave up on competing with the Ford E450.  It offers more interior comfort than the Ford, but not as much as the Sprinter.  It's power & weight ratings are a little less than their Ford counter-parts making them a great chassis for all but the heaviest of class Cs.  One thing to keep in-mind, if you are counting inches in storing your rig, the Chevy is a little longer than the Ford by a number of inches which was critical for us with our garage as seen HERE with our Ford 2007 E350 rig.  That could be the reason why the Chevy has a little more interior driver/passenger leg room.
The E350 & E450 with V10 engine was discontinued some years ago.  Today the majority of class B+ and C motor homes are built on one of them with 7.3L-V8 engine for a number of very good reasons.  They have more power and load capability than the other choices.  Ford approves outfitters to modify the chassis to increase or decrease the wheel base which provides motor home companies a lot of design freedom.  Ford has off-the-shelf components that work with the wheel base modification.  So if you need a new drive shaft, fuel line, brake line, parking brake cable, wire harness, whatever, Ford has them available.  Finally, the E350 & E450 chassis are competitively priced.
Engine Power Ratings of Ford, MB-Sprinter, Chevy, and Dodge
Ford E450 - 7.3L-V8, 325hp, 450ft
Ford Transit - 3.2L-I5 diesel, 185hp, 350ft  (3.5L-V6 twin-turbo direct-injection 310hp, 400ft)
CLICK HERE for Ford Transit and E-Series Motorhome Package Specs.
Mercedes Sprinter Diesel - 3.0L-V6, 188hp, 325ft
Chevy 4500 - 6.0L-V8, 323hp, 373ft
Dodge Promaster - 3.6L-V6 (GVW only 9,300 pounds)
Click on the video below for a slide-show presentation on the construction of a Phoenix Cruiser and turn up your volume. It was made in 2007 and updated a year later. As old as this presentation is, Phoenix Cruisers are still made this way today.
I feel this presentation teaches so much, especially about hidden things that unsuspecting buyers would never think about.
 THE MAKING OF A PHOENIX CRUISER MOTORHOME
« Last Edit: June 13, 2025, 11:04:18 am by Ron Dittmer »
Amsoilman
  • 68
  • PurchDate: 2024
  • IntColor: Grey
  • ExtColor: White Grey
« Reply #2 on: June 13, 2025, 05:02:52 pm »
Well written Ron!  I really love my 2016 3100. It drives and rides so nicely.
Taildragger
  • 209
  • ExtColor: Greystone
The best older motorhome brands
« Reply #3 on: June 21, 2025, 11:51:06 am »
Very interesting summary of reasons to support Phoenix Cruiser.  In the world of RVs, it’s important to remember that longevity is influenced by a multitude of factors. First off, the materials used, and construction technique play a significant role. RVs made from high-quality materials like fiberglass tend to withstand the elements much better than those constructed from lower-grade materials.
Our PC currently has accumulated 107,000 miles and just completed a roundtrip of over 5,000 miles.  I am happy to report it is holding together.
flei
  • 89
  • PurchDate: 03/2020
  • IntColor: ?
  • ExtColor: ?
« Reply #4 on: June 23, 2025, 09:39:15 am »
I agree about the high quality of Phoenix Cruisers! At least this is very true of our 18 year old 2007 2350 which now has 105,000 miles on it. Our longest trouble-free trip was 18,000 miles. We have driven it over some of the roughest paved and dirt roads in North America (with even the occasional off-road excursion) and have never had any failures.
There have been ZERO problems with the chassis, drive train, or cabin structure (interior and exterior). Other than the macerator system (which was not working when we bought it in 2020) all the appliances, systems etc. are still working (knock on wood!). Even the slide-out has been trouble free (I've probably jinxed it now!). The Onan generator is the only thing that is quite unreliable (note: this is of course NOT built by PC but by Cummins) (we do not care because we NEVER use a generator anyway thus I have not spent the time to deal with its fueling problems). Cosmetically the exterior does look like hell because the clear coat failed years ago.
Importantly I will note that both prior owners were very mechanically adept and did an excellent job maintaining it which I also try my best to do. IMO owning a motorhome is NOT for those not knowledgeable, interested or able to put in a good amount of time and money to keep this truck/house-thing in good shape!
The important thing is not to stop questioning. Curiosity has its own reason for existence.- A. Einstein
Sarz272000
  • 369
  • Model: None
« Reply #5 on: June 23, 2025, 01:47:53 pm »
I see a Hoosier Cruiser is for sale on RV Trader.  Those are the same people that built most of the PCs prior 2019 or so.  They do not use the Swintek slide but the original PC slide.  They have ducted air and a number of small improvements that make things better.  Not sure how successful they are in selling units.  But it is another option.
In my opinion, PC still makes a quality unit.  They just priced themselves out of the market when they went from factory order to dealer network. They just restarted a prototype for a Super Class C.  So that model may not be available for a while.  It also seems like all RV sales have tanked.  Used RV prices are diving.  So the coming months may be buying opportunity for interested purchasers.
Ron S
  • 685
« Reply #6 on: June 24, 2025, 10:00:05 pm »
Most rv shoppers  have never even heard of a Phoenix Cruiser.
After 9+ years of adventuring around  CA and the southwest Iv’e only seen 2 other PC’s, a 2350  and a 2100.
This website currently shows PC factory outlets in just 5 states.
wideglide
  • 54
  • PurchDate: 6/2026
  • ExtColor: gray
« Reply #7 on: July 28, 2026, 11:36:17 am »
While i was shopping one of my resources was a guy who is a RV inspector and has a youtube channel and website called RVinspectionandcare. He offered a buyers guide that i got from him of recommendations of brands that he considered the best. I was really looking for a minnie winnie as it was on his list. The PC showed up on a semi local FB marketplace ad and low and behold it was one of the few on his list. I looked at no fewer than 10+ similar floor plans and year models of other manufactures and they all had very concerning structural issues like water intrusion, delamination, soft spots in floors and ceilings.  The PC was near flawless in all those aspects and looked amazing in comparison. IM so happy it showed up for sale and we bought it.
Camperfan
  • 19
  • PurchDate: 04/26
  • Model: 2351
« Reply #8 on: July 30, 2026, 07:00:24 pm »
I looked, and waited, for a short (25’ ) PC in only the model year 2016.
I feel I struck gold when I found a 2016 on a 2016 chassis.
2016 was las year for the LiftCo slide mechanism and the 2016 E450 chassis was first year for the 6speed automatic.
Lucked out that this model 2351s was ordered new with the extended bed/kitchen.
Wasn’t so lucky when it was 2100 miles from home.
  • 685
« Reply #9 on: July 31, 2026, 08:41:17 pm »
Finding a pre-loved PC for sale in the western states always required
patience and/or luck. Now it looks like all the 21-25 ft models are becoming scarcer everywhere else too.
A gently used 2016 with a slideout might be the holy grail of PC’s. The good old reliable Liftco slide mechanism is engineered to last and runs even smoother and quieter if you maintain the jack screws with spray lube. The difference is immediately noticeable.  Do not use the oily or greasy stuff that can collect dirt and grime.
Has the company gone back to factory direct sales? Clicking the inventory link no longer brings up a list of dealerships.
  • 5717
« Reply #10 on: July 31, 2026, 09:35:10 pm »
I sure hope so.  That would bring down the purchase price immensely as well as reopen customization flexibility.
The previous owner, Kermit Fisher, went "factory direct" in response to the great recession of 2008.  It was a bit testy in the beginning with his change in marketing strategy, but as the company's name became more recognized, "factory direct sales" seemed to be a solid winner.  Once dealerships got involved, there was more exposure but the big increase in the purchase price shy'd away many prospective buyers.  I would have been one such person if considering a new motorhome these days.  I could not, nor would not want to invest half the price of a house, into a class B+/C motorhome for our planned occasional use.
  • 685
« Reply #11 on: August 01, 2026, 01:31:38 pm »
Hey Ron, do you recall  what Kermit charged for full body paint back in ‘07?  It’s been standard on all PC’s for the past several years as part of their premium branding. Painting a motorhome is crazy expensive here in CA and  there aren’t many body shops with oversized paint booths. It’s probably a lot less in Indiana but still $$$$ now.
  • 5717
« Reply #12 on: August 01, 2026, 09:53:24 pm »
I have a lot of data for 2007 & 2008 including MSRP of each model, and options.  As I recall, there was no price hike from 2007 to 2008.
When we special-ordered our 2007 PC-2350 in May of 2007, MSRP for Full-Body-Paint was $6020.  Back then, it was the same price for model 2100 as it was for model 2950.  Size did NOT matter.  MSRP for Lower-Body-Paint was $1372.  We did not pay MSRP.  Full-Body-Paint cost us $4631.
Back in 2007 every PC model could be ordered with the exact same slide-out that had a cloth electric sofa bed located directly behind the driver.  It was optional, be it an extremely popular one.  Its MSRP was $4130.  Back then, only the couch/bed was in the slide-out.  The fridge was included either mid-production 2009, or in 2010 or 2011.  My data in not clear as to when.
« Last Edit: August 01, 2026, 09:56:48 pm by Ron Dittmer »
heisthl
  • 17
  • PurchDate: April 30th 2024
  • ModelYear: 2005
  • IntColor: Green
  • ExtColor: White/Green
« Reply #13 on: August 02, 2026, 04:35:52 pm »
I'm very happy with my 2005 (2004?) 2350. It has the solid rear cap with spare, I upgraded the single battery to a 320amp lithium and added a xantrex whole house inverter (easy to install in the closet floor). Upgraded surround amplifier and speakers, and other comfort things and now it's an ideal motorhome for myself and 2 dogs. Can't believe my Fridge is still working after 21 years and 110,000 miles.
jimmer
  • 155
  • PurchDate: 5 / 2016
  • Model: 2700
  • ExtColor: WHITE OVER BLUE
« Reply #14 on: August 02, 2026, 06:41:45 pm »
Hey,  " CALCRUISER ",    what spray lube do you use on your slide-out screw jacks ?      Brand ?    Others feel free to chime in.    Looks like a tough place to access,   Method ?
Thanks, Jim
