Cut through a structural frame member?
  • 17 Replies
  • 32364 Views
LRUCH
  • 238
  • Larry and the "Escape Pod"
  • PurchDate: 08/2020
  • Model: 2900
  • ExtColor: White/Sage
Re: Cut through a structural frame member?
« Reply #15 on: March 28, 2024, 02:51:07 pm »
Folks, a couple thoughts here.
1. When I took the factory tour back in May 2022, I didn't see any boxes to support a table leg built in to the floors.  The floor seem to only have deviations for the entry step, the right rear storage drawer and the wheel wells for the rear duals. I've attached a photo of a stack of various floors before the insulation and wood sandwiching.   But,,,  that's not to say the process hasn't changed over the years.
2. In the 1st pic at the top of this thread we haven't called out the fact the hole shows all wood and steel.... No foam insulation.  So maybe the process years ago was to build a wooden box?   Interesting.
Larry
Larry
  • 5744
« Reply #16 on: March 28, 2024, 11:33:02 pm »
That picture blows my theory out of the water.
Interesting observation.  Why a solid plywood hole?  Where is the white foam insulation?
I wonder if 100% plywood was used where the generator, propane tank, battery compartment, and seat belts are bolted up to prevent crushing the sandwich when tightening the bolts.
« Last Edit: March 28, 2024, 11:39:55 pm by Ron Dittmer »
« Reply #17 on: April 01, 2024, 01:25:37 pm »
« Last Edit: April 01, 2024, 01:29:19 pm by CalCruiser »
